Default best sender for factory 15 gal tank
Old 05-25-2018, 11:21 AM   #1
squishware is offline
squishware
Vehicle(s): 1982 CJ7, 1989 GM 4.3 V6, Dana 300, T5, 3.54 gears
squishware's Avatar
Rep Power: 0 squishware is on a distinguished road
https://www.rockauto.com/en/moreinfo...sn=393&jsn=393
OR?
Thanks in advance.
Default Re: best sender for factory 15 gal tank
Old 05-25-2018, 12:17 PM   #2
mriplaybass is offline
mriplaybass
mriplaybass's Avatar
Rep Power: 7 mriplaybass is on a distinguished road
I've used Spectra products in the past. So far, I'm very satisfied. Sometimes, you may have to bend the pickup tube slightly to fit your application. Make sure that the pickup tube is as close to the bottom of the tank as possible.
The Following User Says Thank You to mriplaybass For This Useful Post:
squishware (05-25-2018)
Old 05-26-2018, 04:51 PM   #3
squishware
squishware's Avatar
I reached out to the PO and I have the Novak sender in the 15 gallon metal tank. I have not started troubleshooting yet but I cannot hear the pump run anymore during start up. Does anyone have any experience with the Novak Sender?
https://www.novak-adapt.com/catalog/...j-fuel-module/
Old 05-26-2018, 08:33 PM   #4
What you might want to do first, is check for voltage to the fuel pump when the ignition is first turned to the on position. As I recall it is for about 2 seconds to charge the fuel system. A fuel pressure check from the fuel inlet in back of the t.b.i. just to know how it is working.
The Following User Says Thank You to Torxhead For This Useful Post:
squishware (05-27-2018)
factory , gal , sender , tank
1975 CJ5 fuel sender/tank meter dnl75cj Chassis and Body 5 03-05-2017 09:13 PM
Fuel sender driver007 Chassis and Body 7 02-20-2015 03:52 PM
BEST in tank fuel pump and sender for GM TBI on cj7 jeep! 76cj7chick Drivetrain 37 08-01-2014 09:56 PM
Which fuel sender is best? Rexx66 Misc CJ Discussion 8 07-07-2013 08:25 PM
Gas fumes from tank sender seal 1970 beepbeep Drivetrain 3 10-11-2010 05:12 PM
