Default Alternator wiring
Old 02-05-2012, 04:22 PM   #1
ftwflh is offline
ftwflh
Vehicle(s): 1976 CJ 5, 232 6cyl 3spd lots of rust,good frame,Dana 44s w/373 gears,ProComp 4in lift kit
ftwflh's Avatar
Rep Power: 10 ftwflh is on a distinguished road
MY alt has a big wire going to the battery with a small wire going from the clip on the side of alt to the big wire and a white wire just hanging out of the plug on the side.Where does the white wire go?
I put on a new battery but it doesnt act like it is charging.Take the ground cable off and it dies.Battery shows 12.5 volts not running 12.3 running.
Any input appreciated.
Default Re: Alternator wiring
Old 02-05-2012, 07:34 PM   #2
cwacj7 is offline
cwacj7
Vehicle(s): 1982 cj7 258 auto .030 bore out bigger cam 1986 cj7 258 auto
Rep Power: 0 cwacj7 is on a distinguished road
it sounds like the wiring to the alt my 82 has two wires on the side one red and one black
Old 02-05-2012, 08:06 PM   #3
Stodg73 is offline
Stodg73
Vehicle(s): '79 CJ5, 258 ci, 4.2L, T-150, DANA 20, DANA 30, AMC 20, 3" body lift, 33's
Stodg73's Avatar
Rep Power: 9 Stodg73 is on a distinguished road
Here is a pic of my alternator wiring. The black wire goes to the Voltmeter inside.
The orange wire with the circuit breaker, which is connected to the 10g red wire on the back of the alternator, is going to the starter solenoid closest to the battery.
Hope this helps.
'79, CJ5, 258 ci, 4.2L, T-150, 3" body lift, 33x12.50x15 Bringing it to stock, then tearin' it apart and putting it back together
Old 02-05-2012, 08:13 PM   #4
ftwflh is offline
ftwflh
ftwflh's Avatar
Thanks I found this link and it really helped
Pirate4x4.Com - The largest off roading and 4x4 website in the world.
Old 02-11-2012, 10:28 AM   #5
ftwflh is offline
ftwflh
ftwflh's Avatar
NEw battery new Alt.Still no charge. Does both wires out of the side have to be hooked up?
Old 02-11-2012, 03:59 PM   #6
ftwflh is offline
ftwflh
ftwflh's Avatar
Got it fixed. Had to run a wire for the exciter side of the regulator
alternator , wiring
1974 CJ5 Alternator Wiring Sic Misc CJ Discussion 6 04-24-2013 10:12 AM
motorola alternator and regulator wiring GL49 Chassis and Body 3 03-22-2013 02:53 PM
73 CJ Alternator Wiring ThePunisher Chassis and Body 8 09-04-2012 10:27 AM
Alternator wiring assistance Bolzen24 Chassis and Body 2 12-11-2011 02:19 PM
Alternator wiring alaskaviper Chassis and Body 0 08-13-2011 02:35 AM
