Default Alternator Not Charging Battery
Old 05-28-2014, 01:51 PM   #1
MaineMan87 is offline
MaineMan87
Vehicle(s): 1974 CJ5: 304, 3 spd
MaineMan87's Avatar
Rep Power: 0 MaineMan87 is on a distinguished road
After two months of ownership and picking away at some punch list repairs, I was anxious to take my 74 304 CJ5 out this past weekend. I hopped in, turned the key, and nothing. It was clear that the battery was dead, but I didn't think of anything of it, since it had sat all winter before I bought it and another two months after I bought it. I put a charge on it and would try it the following day. It started up with no problems, for about 5 or 6 starts, but then the battery died again. The previous owner installed a new alternator before I bought it, but I was beginning to question if he hooked it up properly. I am not an expert mechanic, and electrical is probably my weakest link, but I quickly noticed that one of the wires coming off the plug of the alterrnator was cut and not hooked to anything. It looks to be a GM style alternator with an internal regulator. There is a 2-wire plug with a red wire and a black wire. The red wire is hooked into the positive lead on my battery, but the black wire goes nowhere. Where should this be connected? I picked up a new battery and solenoid, for peace of mind, but I'd like to get this alternator issue figured out before I throw the new battery in.
Also, while under the hood, I noticed that there is a purple wire that is also disconnected. According to the FSM, this should be hooked to the oil sending unit, is that correct?
Thank you,
Andrew
Default Re: Alternator Not Charging Battery
Old 05-28-2014, 02:42 PM   #2
Rep Power: 13 Torxhead is on a distinguished road
If your fsm does not have a wiring diagram in it, there are wiring diagrams available online or they can be found it aftermarket repair manuals.
Old 05-28-2014, 04:54 PM   #3
jdcaples is offline
jdcaples
Vehicle(s): J0M93ECxxxx J - Jeep 0 - Year 1980 M - 1980: 4-speed Manual 93 -Inches of Wheelbase? E - 4150# GVW C - 6 Cyl, 258 CID, 2 Bbl Dana 300, SR-4, stock and rusting; I'm the fourth owner.
Rep Power: 8 jdcaples is on a distinguished road
Does this look similar to what you have?
-Jon
Old 05-28-2014, 05:00 PM   #4
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
Purple goes from the sending unit to the oil pressure gauge.
The Delco plug issue seems to be a fairly common problem. My Jeep came with a red (or was it black, can't remember) wire hooked to the line going to the battery and a white wire seemingly doing nothing but hang out in space. I asked almost the same question you have and got a steady stream of answers. Most all of them saying that there needed to be some sort of resistor in the line going to the run side of the ignition switch. The resistor could be a light bulb or a few inches of resistor wire. the resistance tells the regulator that there is a load and the alternator needs to start charging. From what I can gather this is mostly for low RPM operation, above a certain RPM the alternator will automaticly start charging. So, what did I do. I cheated is what I did. My alternator fried itself right infront of my little eyes, so I took it in and had it rebuilt with a single wire set-up. Quick simple fool proof. There is only one wire to hook up and thats the heavy with coming from the battery. This effects the way the alterantor starts charging. Start the engine, blip it up over 1100 RPM and you've got charging going on.
But, your wire hanging shouldn't stop your Jeep from charging, what does your volt meter say? It should be running at 14+ volts with a nice 12+ with the engine off.
Old 05-28-2014, 05:16 PM   #5
MaineMan87
MaineMan87's Avatar
Attachment 17564
-Jon
Indeed. Thanks
Old 05-28-2014, 05:17 PM   #6
MaineMan87
MaineMan87's Avatar
I will be checking the volts tonight, but I think you have lead me in the right direction. The alternator is brand new, so I will install a resistor on that wire and see if that fixes the charging issue at low rpm's.
Old 05-28-2014, 05:38 PM   #7
jdcaples is offline
jdcaples
In my CJ7, I have the GM style alternator.
For what it's worth, my Painless Performance Chassis harness came with wires on the back of the fuse panel. It's wire 714. Wire number 714 goes from the fuse panel to terminal 1 on the alternator.
Here's the Painless diagram
Here's the fuse panel end of wire 714 (4th hole from the right, bottom row)
-Jon
Old 05-28-2014, 05:48 PM   #8
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
That is one of he best wiring diagrams I've seen in a long time.
Old 05-28-2014, 11:28 PM   #9
Rep Power: 14 mtnwhlr is on a distinguished road
A quick way to see if the batt is getting volts from the alt is to start it with a charged batt and pull the pos cable off the batt if it still runs the alt is putting out and is fine if it dies than it isn't.
Old 05-29-2014, 12:49 AM   #10
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
AutoZone and O'Rieleys will do a diagnostic check on your charging system for free. A new alternator does not = a working alternator.
Your Jeep should run for a while on a good recharged battery.
alternator , battery , charging
Battery is not charging Joey84cj7 Drivetrain 10 04-18-2014 02:28 PM
intermittent alternator charging escobar Chassis and Body 10 01-27-2011 01:37 AM
Battery/charging issue ppd1107 Chassis and Body 3 01-18-2011 03:22 PM
Alternator/battery question (again) iCEMAN Chassis and Body 4 01-05-2011 09:01 PM
Is it my alternator or my battery? Rotor Wash Chassis and Body 5 10-26-2010 01:20 AM
