Default alternative oil/temp gauges
Old 01-07-2020, 06:31 PM   #1
lowcountry is offline
lowcountry
Vehicle(s): '83 CJ7, 258, D30, amc 20, D300, 4sp, '70 Z28, LSX, 6sp, 711 fwhp (N/A), 2015 2500 HD Duramax/Allison
Rep Power: 1 lowcountry is on a distinguished road
I would like to install some aftermarket gauges. Where is the best place to install an oil pressure sensor and water temperature sensor? This would be for an '83 258... Mucho Gracias.
If you don't know where you're going, any road will do...
Default Re: alternative oil/temp gauges
Old 01-07-2020, 09:11 PM   #2
DC712001 is offline
DC712001
Vehicle(s): 1979 Jeep CJ5, 304 V8, Dana 44 Rear 1975 Jeep CJ5, 304 V8 1971 Dodge Charger SE, 440 V8 1974 Dodge W200 Powerwagon, LA 360, 4-Speed 1969 MGB 2001 Acura CL 1985 Corvette 1982 Camaro Z28
Rep Power: 0 DC712001 is on a distinguished road
Couldn’t you just use the Factory Oil and Temp sending units or those existing mounting locations to mount New sensors/sending units?
Of course, this would somewhat depend on what “New” replacement gauges you plan to use. If you know which brand/model replacement gauges you plan to use, you should be able to go online and download installation instructions and specifications for the New gauges.
The New gauges may require different or supplied sensors/sending units.
Perhaps the existing factory sensors/sending units still work and would drive the New gauges?
Old 01-07-2020, 10:30 PM   #3
RiverandSand is offline
RiverandSand
RiverandSand's Avatar
Autometer classic gauges will fit in the stock holes. Mechanical oil gauge (only way to go IMHO) Either electric or mechanical water temp.
Old 01-08-2020, 02:19 PM   #4
Basod is offline
Basod
Basod's Avatar
Mechanical on both was my choice.
Auto meter 2432 for water temp, you'll need to drill a hole large enough for the bulb & nut to fit through firewall ran my on DS firewall and installed in plug under the intake/exhaust manifold, just slit the provided grommet and use care routing the line to not kink it. Get an under dash bracket to mount it.
Oil pressure 2421 fits the stock hole with supplied nylon tubing kit and grommet run it through the PS firewall near the left of valve cover. Unthread the stock sender has the purple wire attached and thread in the 1/8" NPT adapter. Copper line kits are 12-15 extra if you want the extra insurance
The Following User Says Thank You to Basod For This Useful Post:
lowcountry (01-09-2020)
alternative , gauges , oil or temp
Gas and Temp gauges: down the rabbit hole I go boney Chassis and Body 15 12-04-2017 08:15 AM
Temp and fuel gauges 2.0 Rescuejeff Chassis and Body 16 05-03-2014 12:04 PM
fuel quantity,temp,voltage,& temp gauges not working johnmoers Chassis and Body 3 02-19-2014 09:42 AM
Temp and fuel gauges..again bearsden Drivetrain 6 10-21-2013 02:34 PM
gas and coolant temp gauges satxcj Chassis and Body 8 07-14-2011 01:00 AM
