Default 55-75 Jeep CJ-5 Passenger Seat Bracket
Old 11-24-2019, 07:34 PM   #1
ZDD is offline
ZDD
Vehicle(s): 74 CJ5, 304.
Rep Power: 0 ZDD is on a distinguished road
I bought a 74 CJ5 earlier this year that used to have the seats welded into the roll cage, making it so it was impossible to get into the tool box under the passenger seat. I decided I wanted to change the seats and how they were mounted. So I started searching all the CJ5 forums and classified sites looking for the stock seat brackets to put back in, I was finally able to find a drivers seat bracket. But I could never find the passenger one. So I decided to make one that would look and function like a stock one.
I used the same diameter of tube and 7 gauge steel as the originals. The only big difference is instead of having the latch mechanism to hold the seat down in the back. I used a detent pin above the hinge to keep the seat from lifting up.
I know the trouble I went through of looking for weeks and not being able to find one that works. And Id like to help others with the same problem get there jeeps back on the road.
So if any one needs one and is interested let me know and I can see about making more.
Default Re: 55-75 Jeep CJ-5 Passenger Seat Bracket
Old 11-24-2019, 08:03 PM   #2
Belizean is offline
Belizean
Belizean's Avatar
Nice You do good work !
ZDD (11-24-2019)
Old 11-24-2019, 08:21 PM   #3
TnCJ is online now
TnCJ
TnCJ's Avatar
Rep Power: 1 TnCJ is on a distinguished road
That looks awesome! Great job!
The Following User Says Thank You to TnCJ For This Useful Post:
ZDD (11-24-2019)
Old 11-24-2019, 09:52 PM   #4
Patrick is offline
Patrick
Patrick's Avatar
Rep Power: 0 Patrick is on a distinguished road
I have the same dilemma and gave up looking for those seat mounts. My tub is different and lacks the raised coffin, its the same on driver and passenger side. I will have an additional fuel tank under the passenger seat.
ZDD, can you list the size and type of material you used for the tube and flat bar... did you use cold rolled steel... your work looks awesome.
I believe my model had a long tube all the way across for both seats with a middle support. My online search results were very limited in detail and inconsistent. The classic CJ parts suppliers dont carry these mounts.
CJs are not getting older, they are getting faster!!!
Old 11-25-2019, 03:45 AM   #5
ZDD is offline
ZDD
Patrick, that's a cool idea to have a second fuel tank under the passenger seat!
As for the material the tube is 1 in. outer diameter by 0.120 in. thick wall. The flat parts are 7 gauge or 3/16 in. thick and it is cold rolled steel.
I haven't seen a bracket that looked like the one your describing. But it sounds like the middle support would go down where the drivers seat bolts to the floor normally.
Old 11-27-2019, 05:15 AM   #6
Project86 is online now
Project86
Vehicle(s): 1986 CJ 7 Blue 2004 Chevy LWB CC, 2012 Corvette Grand Sport 1986 CJ 7 Red Garnet 1978 CJ 7 Kinda Orangish
Rep Power: 10 Project86 is on a distinguished road
Trick! I like it.
55-75 , 70-71 , 74-75 , bracket , cj , cj-5 , jeep , original , passenger , seat , seat bracket , stock
Passenger seat pivot latch Colo Dean Chassis and Body 13 04-06-2015 08:28 PM
Newbie looking for 1973 -1975 CJ5 Passenger Seat Hold Down Bracket Lawson001 Chassis and Body 2 09-21-2014 01:29 PM
Passenger side seat slider Redman Chassis and Body 8 02-03-2012 04:05 PM
1974 jeep seat/bracket cj258 Chassis and Body 2 04-08-2011 11:56 PM
Passenger seat too high RTRCJ7 Chassis and Body 11 07-12-2010 02:47 PM
