Default 1986 frame help
Old 11-10-2019, 12:13 PM   #1
K9kodi is offline
K9kodi
Vehicle(s): 1986 cj7
Rep Power: 0 K9kodi is on a distinguished road
Picking up another cj7 project this week from a friend. He was the original purchaser in 1986. Has the usual front floorboard rot, not too bad but could warrant new pans. Has the rocker panel rot. Iíll do those as well. Other then that he wrecked it a little last year, busted front driver fender and Bent the frame a little. Iím
Or opposed to welding on a new section of frame , say from front tub body mount forward, with a tape the rest of the frame shows square. Any idea where to source these parts. I am am hobbyist welder but have been for 20 years and have some good machines and tools now so Iím not worried about the welding. Only reason Iím
Entertaining the project is cause itís free to me.
86 cj7, 6cyl. Original hardtop,
Default Re: 1986 frame help
Old 11-10-2019, 01:11 PM   #2
Manic Mechanic is offline
Manic Mechanic
Manic Mechanic's Avatar
Images: 11
If the frame is only a little bit bent u will cause more damage splicing a section in. Your best bet is to have a body shop pull the frame back into square using a frame machine and computer measurements
1986 , frame
Will a 1986 cj7 skid plate fit a 1976 cj7 frame? 76cj7chick Chassis and Body 17 01-13-2016 05:02 PM
1986 CJ Rollbar Scoob Chassis and Body 25 10-07-2012 11:49 AM
1986 cj7 coldair Misc CJ Discussion 18 11-26-2011 11:17 PM
denvar03 1986 cj7 DENVAR03 Introductions 3 09-26-2011 09:52 PM
1986 cj7 258 greg7 Drivetrain 7 09-05-2011 08:35 PM
