Default Reverse light wiring questions
Old 07-30-2015, 04:49 PM   #1
Flex BT is offline
Flex BT
Vehicle(s): 1981 CJ7. I6, Weber 38/38 with TEAMRUSH upgrade. T5, Dana 300TC, Dana 30 / AMC 20, True trac w/ 4.10s. 33" All terrains Blue and rust colored.
Rep Power: 8 Flex BT is on a distinguished road
What I've got: the wires going from the trans / transfer case to the molex connector / harness connector thingy:
Wires going from the reverse lights to an area by the parking brake:
The two light green wires by the parking brake are labeled "to brake lights" and to "brake lights power +B" or something like that. When the "to brake lights" gets 12v the brake lights come on.
My questions:
I'm assuming I need to get the two green wires through the firewall. How do I do that? Shouldn't they be connected to the back of the fuse box (or that relay?), with a harness coming out the other side to connect to the transmission side? I can't see anywhere on my engine side of the firewall that has any wires labeled for the backup / 4WD lights or any connectors that look anything like the plug coming off the tranny/xfer case.
edit: Please fix the email notifications for replies! I don't want to have to check this thing every few hours or forget about it being here.
Default Re: Reverse light wiring questions
Old 07-31-2015, 04:26 PM   #2
Flex, are you looking to hook up the back up lights? Since that circut comes from the bu/seat belt fuse which is hot with the ignition switch in the on position. Actually any fused ignition on hot line would work.
Old 08-01-2015, 06:48 AM   #3
Flex BT is offline
Flex BT
Yes, I am trying to hook up the back up (reverse) lights and 4wd indicator.
I don't think there is such a fuse on my panel. Even if it was, shouldn't there be something that molex style connector / harness attaches to on the engine side of the firewall, or is that something the PO removed when installing the painless harness?
Old 08-01-2015, 04:31 PM   #4
jdcaples is offline
jdcaples
Vehicle(s): J0M93ECxxxx J - Jeep 0 - Year 1980 M - 1980: 4-speed Manual 93 -Inches of Wheelbase? E - 4150# GVW C - 6 Cyl, 258 CID, 2 Bbl Dana 300, SR-4, stock and rusting; I'm the fourth owner.
Rep Power: 8 jdcaples is on a distinguished road
This manual might help
https://www.painlessperformance.com/Manuals/10150.pdf
-Jon
Old 08-01-2015, 06:51 PM   #5
Flex BT is offline
Flex BT
I have seen the painless manual. My PO removed the pigtail that goes between the transmission and bulkhead (the one pictured) and I don't know where those wires need to run to on the bulkhead. I think the three wires on that pigtail all need to go to the bulkhead on Reverse signal, 4WD signal, and reverse signal power, right? I can't find those in the manual on the bulkhead except for the 4WD indicator. I'm also having a hard time finding out where the two wires in the other picture need to hook up on the interior.
light , questions , reverse , wiring
Wiring Nightmare!... No reverse, blower, gauges... jbdoom87 Chassis and Body 2 03-29-2014 09:45 AM
Tail Light Wiring jswatson0917 Chassis and Body 1 09-10-2012 11:14 PM
Reverse light Germy Chassis and Body 5 08-31-2011 08:27 PM
Tail light wiring. Germy Chassis and Body 3 08-14-2011 09:10 PM
Reverse light switch and general tranny questions. nctom Drivetrain 8 08-09-2010 04:00 PM
