Default Question: Return to Carb from Fuel Injection
Old 11-05-2019, 10:18 PM   #1
ELK CJ is offline
ELK CJ
Vehicle(s): 80 CJ5
Rep Power: 0 ELK CJ is on a distinguished road
I have purchased my first CJ5 (1980 with a 6 cylinder and first generation Holly fuel injection). I want to return the jeep back to a 2B carburetor. The current system is ok - the jeep now runs and drives good, but is not reliable; i.e. the fuel injection system is not computerized (manually tuned), the electric fuel pump and control module are no longer available, as well as some of the other smaller component parts. Gas mileage is about 8 MPG. Bottom line... concern is that if I break down and really need assistance, I will wish I had modified this jeep. That said:
What 2 barrel carb and tricks would one recommend to return this rig to stock plus (reliability)? Specific brand and source?
Any special fuel pump issues (as the original one was removed and block plated?
Default Re: Question: Return to Carb from Fuel Injection
Old 11-05-2019, 10:23 PM   #2
Manic Mechanic is offline
Manic Mechanic
Manic Mechanic's Avatar
Images: 11
Well if u don't want a new fuel injection set up go with the tried and true MC 2100 off a 72 bronco with the 302 it should have the 108 ventricle.
Old 11-05-2019, 10:46 PM   #3
jzak is offline
jzak
Vehicle(s): 1981 CJ5/258 4.2L I6, Tremec T-176 4-speed, Dana 300, Power Steering, Howell Throttle Body Injection System, Warn Locking Hubs, Warn Rock Crawler front/rear bumper with Tire Swing Carrier, Full Roll Cage, Pro Comp ES9000 shocks
jzak's Avatar
Rep Power: 6 jzak is on a distinguished road
I would maybe try to work with the system you have then going back to a Carb which is going to have its own set of problems. I've lived with both a 2BBL Carb, and a TBI, and I can say without a doubt the TBI was more reliable. I'm sure you can easily get aftermarket parts for your kit like inline fuel pumps and filters. Holley is not exactly a mom and pop shop.
I would recommend calling Holley to get some help in troubleshooting these problems, such as the low gas mileage. When I had problems with my TBI, I called the manufacturer Howell, and they were extremely helpful in finding a solution.
Quick question. Are you sure it doesn't have a computer? I've never heard of an injection system without some kind of onboard computer system monitoring everything. You mention that it has a control module. That usually houses the computer.
Good Luck!!
Old 11-05-2019, 11:42 PM   #4
JeeperChris is offline
JeeperChris
JeeperChris's Avatar
Rep Power: 1 JeeperChris is on a distinguished road
My '79 CJ5 with 258 had the stock BBD 2 barrel carb when I got it, which was recently. That ran just fine to me. I swapped it out for a Weber 32/36 and I really enjoy it, so I can say those two carbs work just fine.
From everything I've read on here and other forums, the Motorcraft 2100 seems to be the best fit to a Jeep 6 cylinder. It seems to outperform the other carbs just on the basis of it's simplicity. I used to rebuild carbs and do a lot of modifying back in the day so I am physically familiar with the 2100 I just have not used one on any of my own vehicles, but I would recommend it for sure.
Old 11-07-2019, 05:53 PM   #5
007 is offline
007
Vehicle(s): #1 - 1977 CJ-7 Renegade (Daisy Jane), Levis trim, 304 V8, TH400, QuadraTrac w/Low Range, Dana 30, Trac-Lok AMC20, 3.54's, Factory Air, Tach, Clock, red with Levis blue seats and top(s), 31x10.50x15 Destination MT's, Edelbrock Performer intake, Holley Sniper EFI, MSD6, MSD ProBillet distributor, OME shocks, one-inch shackle lift, Reese tow bar, G2 one-piece axles. #2 - 1984 CJ-7 Laredo (The Texas Hooker Project), 401 V8, 700r4, Spicer 18, Waggy 44's, 5.38's, TrueTracs, SOA, YJ rear sprgs, Waggy front, tach, clock, red with gray seats and top(s), 35x12.50x15 Mickey Thompson Baja MTZ's, Edelbrock Performer intake, Holley Sniper EFI, MSD6, Sniper Hyperspark distributor, Rocky-Road shocks.
007's Avatar
Rep Power: 9 007 is on a distinguished road
Those first gen Holley systems were difficult at best.
No chance you want to go to a newer unit?
Old 11-07-2019, 06:24 PM   #6
MC2100 is best way to go for sure
carb , fuel , injection , question , return
Fuel Injection kolkim Drivetrain 10 05-02-2014 02:15 PM
Problems with Carb throttle return spring... help ID? Rexx66 Drivetrain 5 07-14-2013 05:45 PM
Fuel injection ID idenisovich Drivetrain 1 06-29-2012 02:25 PM
Fuel Injection 81laredo Drivetrain 41 03-08-2010 08:16 PM
dumping tbi going carb FUEL pump question! biohazard cj Drivetrain 11 01-29-2010 10:51 PM
