Default CJ5 Gas Pedal Sensitivity
Old 11-23-2012, 12:04 PM   #1
bdowns is offline
bdowns
Vehicle(s): 1979 Jeep CJ5
Rep Power: 0 bdowns is on a distinguished road
The gas pedal in my CJ5 (304) is kinda stiff and when off-roading, causes me to be a bit jerky on it. I was wondering what all I can do to loosen it up a bit. Thanks in advance for the help!
Default Re: CJ5 Gas Pedal Sensitivity
Old 11-23-2012, 12:20 PM   #2
It may be that your throttle cable is gumed up. I would take it off and spray something like WD40 down it and work it back and forth untill it frees up.
The Following User Says Thank You to mtnwhlr For This Useful Post:
bdowns (11-23-2012)
Old 11-23-2012, 12:22 PM   #3
bdowns is offline
bdowns
Ah good call. I hadn't thought of that. I was googling around for a new "lighter" spring. I'll try that today before I do anything else.
Old 11-23-2012, 01:46 PM   #4
gert is online now
could be the gummed up cable which they make replacements for, Also could be a gummed up throttle shaft on the carb, or your PO could have added an extra spring on the throttle, you should have no more than 2, you can also goto the parts store and get new springs
The Following User Says Thank You to gert For This Useful Post:
bdowns (01-14-2013)
Old 01-14-2013, 12:25 PM   #5
bdowns is offline
bdowns
I replaced the cable as well as worked the spring sum and also let it soak in WD-40 for a little while. All of that seemed to do the trick. Thanks or all the great advice!
Old 01-14-2013, 12:36 PM   #6
Glad to hear you got it fixed
cj5 , gas , pedal , sensitivity
Gas pedal/pad install - can't believe I have to ask CJ7inNH Misc CJ Discussion 4 06-28-2012 02:42 PM
Brake pedal pad browndog314 Introductions 4 01-05-2012 12:43 AM
PV & Pedal pushrod question. jchrisk1 Misc CJ Discussion 4 08-05-2011 07:26 PM
Brake Pedal climberman Misc CJ Discussion 16 03-09-2011 09:32 AM
gas pedal mylittlecj5 Chassis and Body 7 02-01-2011 07:37 AM
