Default Brake Pedal
Old 03-06-2011, 08:51 AM   #1
climberman is offline
climberman
Vehicle(s): 1979 Cj5
Rep Power: 0 climberman is on a distinguished road
I have a 1979 CJ5 and we are almost done putting it back together. I need to know what stops the brake pedal from coming to far. Now if you pump the brakes say to bleed them the pedle keeps bending he metal part that hits the brake light switch and it bends and the pedal starts coming up to far. It eventually starts hitting the dimer switch. Could someone take a picture of there CJ brake pedal and post it or email it to me.
Rocky
Default Re: Brake Pedal
Old 03-06-2011, 11:18 PM   #2
Sasquach is offline
Sasquach
Sasquach's Avatar
Images: 35
Rep Power: 13 Sasquach is on a distinguished road
Hey climberman are you refering to the top of pedal travel? sounds like you are but your post is a bit hard for me to follow. The pedal has a pin to stop return travel but should not reach that if the master cylinder push rod is correct and attached to the pedal because that should stop return travel.
Old 03-06-2011, 11:48 PM   #3
climberman
I will look for a pin there most not be one because it doesn't stop coming up. as for the master cylinder the rod that connects to the pedal comes right out, it is not connected to the rest of the cylinder.
Old 03-07-2011, 10:52 AM   #4
Busted Knuckles is offline
Busted Knuckles
Vehicle(s): 86' Cj7
Rep Power: 10 Busted Knuckles is on a distinguished road
Im not sure what youve got going on by your description, but will snap a picture of a pedal assembly that is out of a cj today and post it later, in the event that helps you figure out what you got going on....
Old 03-07-2011, 01:09 PM   #5
climberman
Would really appreciate a picture Thanks man
Old 03-07-2011, 03:27 PM   #6
Busted Knuckles
Vehicle(s): 86' Cj7
here you go!
Old 03-07-2011, 04:49 PM   #7
climberman
I was hoping that the pictures were from under a dash because there should be a bracket that stops the brake. It wouldn't be on the pedal assembly. Here is a picture of a part I have that I couldn't figure out were it goes. But it looks like something that would stop the brake just not sure how it would work it probably isn't anything.
Old 03-07-2011, 11:06 PM   #8
Busted Knuckles
Vehicle(s): 86' Cj7
Ive got an 1980 in the barn, I take you a pic of that assembly tomorrow....its still assembled.
Old 03-07-2011, 11:09 PM   #9
climberman
Thanks Man
Old 03-08-2011, 09:54 AM   #10
Sasquach is offline
Sasquach
Sasquach's Avatar
Images: 35
That looks like a home made bracket to me. Looked at mine again and the rod to the brake booster linkage stops the return travel. You don't say if you are power or manual but do say the rod comes out of your master cylinder so I have to guess? you have manual and my original manual MS the rod is fixed in and does not fall out leaving me to think it performed the same job of stopping return.
brake , pedal
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Brake pedal to high dlmalone81201 Misc CJ Discussion 5 07-15-2012 08:19 AM
Brake pedal frozen impalamike Suspension and Steering 2 05-29-2012 10:57 PM
Brake pedal pad browndog314 Introductions 4 01-05-2012 12:43 AM
Play in Brake Pedal ballzdeep Misc CJ Discussion 10 11-06-2009 06:48 PM
brake pedal comes up too high banjerman Misc CJ Discussion 8 10-25-2009 09:27 PM
