Default another stupid QUESTION
Old 04-06-2010, 06:08 PM   #1
SANDBLASTER is offline
SANDBLASTER
Vehicle(s): CJ-7 258 inline six,4speed ,AMC 20/30diffs,331 gears FRONT AUSSIE LOCKER,BDS 3 INCH SUSPENSION LIFT, 33X1250X15 BFG AT'S
SANDBLASTER's Avatar
Rep Power: 11 SANDBLASTER is on a distinguished road
What the heck is back spacing in regard to rim selection and what effect does It have ??? What do I need to know about this when I am choosing a new rim?...
Default Re: another stupid QUESTION
Old 04-06-2010, 06:26 PM   #2
Resident 'Old' Jeep Shaman
Images: 141
Rep Power: 13 BajaEdition is on a distinguished road
Before going into a long and complicated post trying to get as much info as possible into a confined space
let me just direct you here
https://www.rsracing.com/tech-wheel.html
ps, no question is stupid, not asking a question is stupid,
Old 04-06-2010, 07:38 PM   #3
BrockGrimes is offline
BrockGrimes
Jeep-CJ.com Archive Master
Vehicle(s): 08 Jeep JK :O
BrockGrimes's Avatar
Images: 103
Rep Power: 14 BrockGrimes is on a distinguished road
Here ya go:
Old 04-06-2010, 07:42 PM   #4
BrockGrimes
Images: 103
Basically back spacing is the distance from the edge to the mounting surface.
The more negative back spacing the more the wheel will stick out away from the vehicle, however this also puts stress on the axle.
Ideal is to have no negative or positive, the wheel mounting surface will be centered
and you'll have less strain on the axle.
Old 04-06-2010, 09:41 PM   #5
SANDBLASTER
SO? Is there a preferred back spacing for a rim on a 81 cj-7 narrow trac going to a 33x1250x15 tire ? example 3.75 BS on a 5 on 5.5 15x8
Old 04-06-2010, 09:44 PM   #6
Do you have options?
Old 04-06-2010, 09:53 PM   #7
SANDBLASTER
Not sure what you mean.
Old 04-06-2010, 09:57 PM   #8
Sasquach is offline
Sasquach
Sasquach's Avatar
Images: 35
Rep Power: 13 Sasquach is on a distinguished road
A 4" backspace is as close as you can get to your calipers assuming disc brakes. Up to 31" tires and you will be good on lock to lock clearance with your leaf springs. Going bigger on the tires will mean you need less backspace to move the tire out farther for clearance.
If you are going with 33x12.5 you will want less backspace than 4" say 2-1/2" but trying to find the wheels you want with those numbers tough, you may have to then think about wheel spacers to gain tire clearance.
Old 04-06-2010, 10:03 PM   #9
how many different back space dimentions do wheel manufacturers give you on an 8" wide wheel? If stock is 4" I would say you will not be able to have more with out dragging the tire and depending what width the new tire is, say 2" wider than stock, you may want less back space, 3" perhaps. this way all the additional rubber moves away from the wheel well to keep the inside edge close to the original position, relitive to the wheel well.
Old 04-06-2010, 10:13 PM   #10
SANDBLASTER
OK! so I'm not the sharpest knife in the drawer BUT ...
will the 3.75 inch BS work with the 33X1250X15 tire on my 1981 CJ-7
question , stupid
Stupid Question - Brake Master Cylinder Shazam Misc CJ Discussion 7 04-05-2013 09:25 AM
Stupid Question - 304 Dipstick Shazam Drivetrain 4 03-30-2013 10:11 PM
stupid question.... Damnitutk Suspension and Steering 1 04-06-2011 12:46 AM
Stupid Driveshaft Question Rescue Diver Drivetrain 7 06-07-2010 10:05 PM
stupid question for today SANDBLASTER Suspension and Steering 11 02-07-2010 06:59 PM
