Default Would you reuse these Dana 300 shift collars?
Old 01-14-2020, 12:40 PM   #1
1994ranger is offline
1994ranger
Vehicle(s): '79 CJ7, 360, T176, D300, 8.8 rear, D44 front, aspiring to swap a 5.3/4L60E!
Rep Power: 0 1994ranger is on a distinguished road
I am doing a Dana 300 rebuild (first one ever) and am curious if these shift collars are too worn to reuse. One of them has scoring where the pads contact it, and I can feel the ridges. The other does too but its still pretty smooth.
Probably best to replace them but I wanted the input of experts!
Default Re: Would you reuse these Dana 300 shift collars?
Old 01-14-2020, 01:05 PM   #2
Basod is online now
Basod
Basod's Avatar
Those look good to me. New shift pads should be in the kit.
The main thing you're looking for is wear/ridges on the gear surfaces.
Not sure if you're taking apart the shift rails and detents, but I found that there were two different springs in mine and the detent blanks had different depths.
I ended up swapping the springs around in order to get the rails to shift smoothly.
If haven't already check out Gearbox videos on youtube -Paul has a great 2 part on the Dana 300.
Old 01-14-2020, 01:41 PM   #3
1994ranger
Thanks! I used the Gearbox videos for getting it apart and will probably use them again for reassembly. I am upgrading to HD outputs and 4:1 Lomax gears so I'll have plenty of instructions to cross reference. Yes, new pads are in the kit!
Old 01-14-2020, 04:01 PM   #4
Patrick is offline
Patrick
Patrick's Avatar
Are your old gears in good shape? I need them.
Old 01-14-2020, 04:20 PM   #5
1994ranger
Old gears appear to be in pretty good shape. I am planning to hang on to them for now but will keep you posted if things change. May be a few months but I'll let you know!
The Following User Says Thank You to 1994ranger For This Useful Post:
Patrick (01-15-2020)
Old 01-14-2020, 05:39 PM   #6
Patrick is offline
Patrick
Patrick's Avatar
Thank you. They are not easy to find, fyi.
Old 01-15-2020, 12:45 PM   #7
JeepCJ5 is offline
JeepCJ5
Vehicle(s): '81 CJ5 - 258, D300, AMC20, D30
JeepCJ5's Avatar
Rep Power: 4 JeepCJ5 is on a distinguished road
They look fine to me also. I just did my Dana 300 upgrade to Lomax 4:1 gears. Patrick, I would be willing to sell my old gears once I get a few miles on my new setup. They are in good condition. If you want to connect through my email, Justin at ahrens.net, I don't get on here too often. I'm travelling right now, but could send you pics once I get back this weekend.
Justin
The Following User Says Thank You to JeepCJ5 For This Useful Post:
Old 01-15-2020, 12:55 PM   #8
1994ranger
Justin
I am doing the same thing, and while I had the collars out, I thought I'd ask about them. Thanks!
Patrick - I am planning to put some miles on my Lomax gears too like Justin, but I am not as far along as him. If he is ready to offload his gears now, you may be better served talking to him rather than waiting on me
Old 01-15-2020, 01:06 PM   #9
JeepCJ5 is offline
JeepCJ5
JeepCJ5's Avatar
Well, I just got my transmission and tcase installed. They are hanging from a rachet strap on the cage right now. I just got the engine started and went through all the gears. It seems good to go. Now I have to connect the driveshafts and skid plate and I can get it on the road for the first time in quite a while....
Old 01-15-2020, 09:56 PM   #10
Ultrunner is offline
Ultrunner
Vehicle(s): Ď85 CJ7, 258, T5, D30, AMC20, D300
Images: 9
Rep Power: 2 Ultrunner is on a distinguished road
I did a Dana 300 rebuild last year. Agree that your shift collars look good. Those things are hackers, they can take a beating. Clean them in some mineral spirits and just use all the new parts in the kit. Itíll feel like butter once you get it all back together with new bearings, seals etc...
Are you replacing the intermediate shaft? Thatís one I would, if one didnít come with the kit. I also had the same issue with the springs under the shift rails. Make sure you install the spring-ball bearing-shift rail unit before you re-install the front bearing cap. Itís a lot easier to access the opening and depress the ball-spring and slide the rail in before you mate it all back up. Also, prolly seems obvious, but donít mix up the shift rails.
300 , collars , dana , reuse , shift
Dana 300 shift rod seals jeepjunk4 Drivetrain 4 08-06-2015 02:45 PM
Dana 20 Shift Rails es335 Drivetrain 1 06-02-2014 02:42 PM
DANA 300 shift lever help! rpsharpe Drivetrain 18 04-16-2014 09:08 PM
Dana 20 shift pattern amcdv Drivetrain 11 04-15-2012 06:14 PM
shift pattern for Dana 20 Robbp Drivetrain 10 05-11-2010 06:57 AM
