Default Re: What Gear Ratio to run
Old 11-09-2018, 07:20 PM   #11
FWIW, I had a set of 35s, which were aired to 28 p.s.i. for the street. I was getting around 3 grand r.p.m. at 60 m.p.h. This is with my T-18 tranny and 4:10 gears. I you compare this with those tire size/r.p.m. charts you can get online, it will show a lot less r.p.m. Although like I said, I only had 28 p.s.i., which makes the tire radius smaller.
Old 11-12-2018, 12:25 PM   #12
jp360cj is offline
jp360cj
Interesting..I'm running 4.10 (actually 4.11 in the rear) on 35s (KM2s @ 30 psi) with a T18 and I'm about 2500 rpm @ 60 mph
The Following User Says Thank You to jp360cj For This Useful Post:
Torxhead (11-12-2018)
Old 11-12-2018, 06:58 PM   #13
Well then I would say we have different speedometer gears in the transfer case.
Old 11-12-2018, 10:43 PM   #14
wooderson64 is offline
wooderson64
Vehicle(s): 79 cj7
Rep Power: 0 wooderson64 is on a distinguished road
Originally Posted by jp360cj View Post
That would have been good info disclose up front...
What auto do you plan to run, and with what transfer case?
Im in no rush to do the swap so I wanted to go ahead and get the right gears for what I have now, the 3 speed. which sound like 4.56 or 4.88s
Any suggestions on what auto trans case to swap in?
Old 11-13-2018, 09:12 AM   #15
jp360cj is offline
jp360cj
Maybe...Is your speedometer way off? Mine is within a couple MPH of GPS. sounds like your 60 mph may have been closer to 70 mph.
gear , ratio , run
Gear ratio jakeh937 Drivetrain 30 03-31-2017 12:22 PM
Gear ratio etexjeep Drivetrain 11 10-13-2014 10:08 PM
Speedometer gear ratio tooth 2,73 axle ratio Chriss Drivetrain 13 10-11-2014 05:49 PM
Gear ratio help!! myfirstcj7 Drivetrain 14 10-18-2012 04:24 PM
gear ratio reptile610 Drivetrain 11 05-11-2012 07:32 AM
