Default What Gear Ratio to run
Old 11-06-2018, 10:31 PM   #1
wooderson64 is offline
wooderson64
Vehicle(s): 79 cj7
Rep Power: 0 wooderson64 is on a distinguished road
Ive got a 79 Cj7, 360 with 3speed, spring over and 35's. Im wondering what the best gear ratio would be to use in the differentials. I only drive the jeep to the trail and do general 4wheeling, a little of everything on the trails. So driving to and from the trail with general trail riding. Thank you for any advice!
Default Re: What Gear Ratio to run
Old 11-07-2018, 06:55 AM   #2
jp360cj is offline
jp360cj
How much highway and at what speeds?
I also have a 360 & 35s and the T18 4 speed is like a 3 speed on the street. I run 4.10s but even with the granny gear, I added a 2.46 low range to transfer case to help out on the tail. If you are going to keep the 3 speed, then I would look at either 4.56s or 4.88s. 4.56s should put you around 2700-2800 rpm @ 60 mph and 4.88 would be around 9
2900-3000 rpm. If you have the AMC20 then I think 4.88 is as low as you can go.
And if you plan on any serious off roading, then I would also plan on going with a 3.15 low range to help out.
But having been there and done that myself, IMO you'll be much better off in the long run to swap transmissions.
The Following User Says Thank You to jp360cj For This Useful Post:
wooderson64 (11-07-2018)
Old 11-07-2018, 09:29 AM   #3
Posi is offline
Posi
Posi's Avatar
What are you running currently, stock 3.54 or optional 4.10?
I would first swap out the T150 for a T18 then address the gears depending on the type of trails you run.
Old 11-07-2018, 04:51 PM   #4
With 35's-Look at 4:56.
You really need to think about a 4 or 5 speed tranny.
If you went to a 5 speed-Then 4:88 would be a better choice.
Old 11-07-2018, 07:19 PM   #5
caveman is offline
caveman
caveman's Avatar
I'm running 4.88s with 35" tires. I wouldn't want to go down the highway without overdrive. Even tho these little 6 cylinders will turn up a lot more than we give them credit for, I still don't like to run them at a high rpm. I guess I'm old.
Sent from my LG-LS777 using Tapatalk
Old 11-07-2018, 11:03 PM   #6
wooderson64
Vehicle(s): 79 cj7
What trans do you have and do you drive it on the street or just trailer it?
Old 11-08-2018, 09:45 AM   #7
caveman is offline
caveman
caveman's Avatar
I drive it on the street often. If I go offroading and know it's going to be rough I trailer it in case it breaks. The wife and I are touring the U.S. presently and I'm trailering it to save wear and tear. It's also our git around buggy while on the road. I presently have the AW4 automatic transmission replacing an AX15 that was there before. This old fat body of mine doesn't bounce like it used to and creeping over an obstacle is more to my style.
Old 11-08-2018, 08:32 PM   #8
wooderson64
Vehicle(s): 79 cj7
I plan on swapping a automatic in maybe 6 months.. you think 4.56s or 4.88s for now and later?
Old 11-08-2018, 09:29 PM   #9
caveman is offline
caveman
caveman's Avatar
I went with the 4.88s because I do some rough offroading from time to time and not usually in a hurry when I take the Jeep down the road. If you're going to do mostly offroading the 4.88s might be what you want. Otherwise I would go with the 4.56s. It will still be very capable with 4.56s with an automatic.
Old 11-09-2018, 09:51 AM   #10
jp360cj is offline
jp360cj
That would have been good info disclose up front...
What auto do you plan to run, and with what transfer case?
gear , ratio , run
Gear ratio jakeh937 Drivetrain 30 03-31-2017 12:22 PM
Gear ratio etexjeep Drivetrain 11 10-13-2014 10:08 PM
Speedometer gear ratio tooth 2,73 axle ratio Chriss Drivetrain 13 10-11-2014 05:49 PM
Gear ratio help!! myfirstcj7 Drivetrain 14 10-18-2012 04:24 PM
gear ratio reptile610 Drivetrain 11 05-11-2012 07:32 AM
