Default Re: Urgent help! Jeep cj7 not going in gear!
Old 06-27-2019, 04:34 PM   #11
Grabber Blue is offline
Grabber Blue
Vehicle(s): '84 CJ7, 304, TH-400, AMC 20, Dana 30
Rep Power: 0 Grabber Blue is on a distinguished road
So Iím 17 rebuilding this project car that was frame off for my first car but my dad and brother started it and they put the trans and motor in and I donít believe they filled up the torque converter with fluid before installing so I think it has to bleed out what would be the best way to do that
Old 06-27-2019, 05:34 PM   #12
shum8 is offline
shum8
Voted most irritating
shum8's Avatar
Images: 2
I think you will find your best course of action in posts 7 & 8.........
Sent via my universal translator
Old 06-27-2019, 06:09 PM   #13
RiverandSand is offline
RiverandSand
RiverandSand's Avatar
On edit: Agreed, the trans pump will fill it just don't over fill it.
Old 06-27-2019, 06:13 PM   #14
shum8 is offline
shum8
shum8's Avatar
Images: 2
He may have to get it fairly level ground. Last report was it was partially down the driveway.
Old 06-27-2019, 06:16 PM   #15
Basod is offline
Basod
Basod's Avatar
Does the dipstick show any level while idling in park?
Get at least a gallon or two of ATF and transmission fill funnel- the caps with fill tubes that attach to gallon jugs are junk, drip and leak every where.
Itís hard to know how how much to add with it being on a slope but donít overfill just a pint or so at a time with the engine idling shift from park to r-n-d-3-2-1 in between additions.
Once you hear/feel engagement check the dipstick and add a bit more, get it to a flat surface and check the level with the engine on and idling in park.
Donít worry too much if over filled a bit it will just leak out your dipstick/fill tube.
Youíll want to check and add before each use until you have to time to drop the pan and replace that seal.
Old 06-28-2019, 10:22 AM   #16
JR74CJ5 is offline
JR74CJ5
Missing-Presumed Wheeling
JR74CJ5's Avatar
Images: 80
Rep Power: 12 JR74CJ5 is on a distinguished road
Originally Posted by Grabber Blue View Post
So I’m 17 rebuilding this project car that was frame off for my first car but my dad and brother started it and they put the trans and motor in and I don’t believe they filled up the torque converter with fluid before installing so I think it has to bleed out what would be the best way to do that
I'm going to over explain a bit of basics just in case - ignore if you already know, but we may be taking for granted that you know some of these basics, and you may not since first project car etc. Most of it has been touched on, just wanted to consolidate it for you. Again, you may know all this and my intent is not to talk down to you at all - just don't want you spinning your wheels (or want you to be rather )
1 - The transmission fluid needs to be checked on level ground with the engine idling (running) and in Park (when you can safely achieve that).
2 - The best way to bleed air out / fluid in everywhere needed is to have the engine running, and shift from Park to Reverse - pause 5-10 seconds or so, then shift to Neutral - Pause again - then Drive - Pause etc - all through all your available shifter positions. When hit the end, go backwards back through them (Holding foot on brake pedal the entire time) - Continue filling a little bit more, and repeating until you start to feel the transmission start to engage in both Reverse and Drive, then get it moved to level ground to continue filling to correct level on dipstick (see #1).
3 - After filling to correct level on stick, do the bleed again (#2 above) and then check it again. Add as needed. Repeat until the level remains full after a bleed process.
4 - Take it for a short drive (if you can legally) around the block seeing if it's shifting ok etc. After you drive it around short distance, then get it back on level ground and check fluid level again.
Auto Transmissions work on fluid pressure, so if you don't have enough, it's very common to not get gear engagement in any position...
All others - I'm doing this from memory - last time I worked on or maintained a auto transmission was probably 10 years + ago - Please make sure you correct anything I said above if incorrect
JR - ECV3
My Build< Click me
Old 06-28-2019, 01:59 PM   #17
Grabber Blue
New issue: I found metal in my flywheel cover 3 small pins and a part of some type of metal gasket any ideas?
Old 06-28-2019, 04:34 PM   #18
shum8 is offline
shum8
shum8's Avatar
Images: 2
Can you post up a couple pics?
An old memory cell of mine is suggesting the transmission should be at operating temp to check fluid level - does that sound right or am I making that up???
The Following User Says Thank You to shum8 For This Useful Post:
JR74CJ5 (07-01-2019)
Old 06-28-2019, 05:42 PM   #19
You be 'rite'-
The Following 2 Users Say Thank You to Lumpy Grits For This Useful Post:
JR74CJ5 (07-01-2019), shum8 (06-28-2019)
Old 06-29-2019, 01:15 PM   #20
RiverandSand
Could be parts of a starter, did you replace a bad starter?
cj7 , gear , jeep , th350 , urgent
Anyone in here good with gear swaps? Gear pattern help request! OldsCool Drivetrain 9 02-20-2019 11:46 AM
Distributor Gear / Cam Gear Reality Check 007 Drivetrain 19 07-14-2017 06:32 PM
40 Holiday Gift Ideas - Gear For Your Jeep Im Not Spam Jeep News and RSS feeds. 0 11-27-2013 12:20 PM
Bantam Jeep Heritage Festival Gear! bantamjeepfest Outdoor Related 0 02-25-2013 05:21 PM
Jeep dies when i shift into gear yetiwarrior82 Drivetrain 6 04-25-2012 10:52 AM
