Default Trans Linkage
Old 08-14-2012, 10:49 PM   #1
Niedhogg is offline
Niedhogg
Vehicle(s): '79 Jeep CJ7 Renegade with 304ci V8, TH400 auto, Quadratrac T-case, Stock 20 and 30 rears with no mods yet, not sure of the gear ratio.. 4" Softride Superlift, w/widetrac shock towers and 35x12.50x15 BFG Mud-Terrains '76 CJ5, 232 ci, T-150 3-speed, D20 T-case, Corp. 20 rear w/full float axles and lockout hubs and Detroit auto locker, D30 front w/lockout hubs, gear ratio is unknown..
Niedhogg's Avatar
Rep Power: 9 Niedhogg is on a distinguished road
Where in the world, can a guy find clutch linkage?? (232 ci, T-150 3-speed) I was busy getting my CJ5 running today, and I happened to notice that the clutch rod to the throwout arm is missing, and then to accomidate this rediculous home made body lift, the primary rod through the firewall was scabbed together with a 3-4" extension... there is also a bracket that was added to mount the z-bar below the body that will need to be delt with.
She runs great though! Of course, I can't drive it until I find 'the missing link' , but it does run!
This is my Jeep. There are many others like it, but this one is mine...'79 CJ7 Renegade, 304-V8, TH400, Qtrac t-case, 4" Superlift, 35" Mud-Terrains.. oooh yeaaa...
Default Re: Trans Linkage
Old 08-15-2012, 08:11 AM   #2
Stodg73 is offline
Stodg73
Vehicle(s): '79 CJ5, 258 ci, 4.2L, T-150, DANA 20, DANA 30, AMC 20, 3" body lift, 33's
Stodg73's Avatar
Rep Power: 9 Stodg73 is on a distinguished road
JC Whitney Clutch Linkage
Morris 4x4 Clutch Linkage
Here are 2 links.
'79, CJ5, 258 ci, 4.2L, T-150, 3" body lift, 33x12.50x15 Bringing it to stock, then tearin' it apart and putting it back together
Old 08-15-2012, 12:54 PM   #3
JR74CJ5 is offline
JR74CJ5
Missing-Presumed Wheeling
JR74CJ5's Avatar
Rep Power: 11 JR74CJ5 is on a distinguished road
Think about using heim joint ends. Works so much better without binding near as much during flex.
~ JR
JR - ECV3
My Build< Click me
Old 08-15-2012, 09:51 PM   #4
Niedhogg is offline
Niedhogg
Niedhogg's Avatar
Here are 2 links.
Thanks, man!
Old 08-15-2012, 09:52 PM   #5
73CJ is offline
73CJ
73CJ's Avatar
Rep Power: 12 73CJ is on a distinguished road
Think about a hydraulic conversion. If that linkage is marginal, it may cause problems under frame flexing.
Old 08-16-2012, 08:30 PM   #6
Niedhogg is offline
Niedhogg
Niedhogg's Avatar
I would if I were going to keep it, but this CJ5 is going back to stock and then getting sold.. I'll be ordering a complete kit so marginal won't be a problem..
linkage , trans
'69 cj5 wiper linkage IowaCJ5 Misc CJ Discussion 4 09-18-2012 06:51 AM
TC linkage slop Slingdog1 Drivetrain 1 09-03-2012 04:46 PM
Clutch linkage kerryfryer Suspension and Steering 11 08-15-2012 11:53 AM
70 cj5 clutch linkage 1970cj5 Drivetrain 2 05-27-2010 08:00 PM
