Default Throttle linkage bracket - weber 38 install help needed
Old 08-16-2012, 11:52 AM   #1
Flex BT is offline
Flex BT
Vehicle(s): 1981 CJ7. I6, Weber 38/38 with TEAMRUSH upgrade. T5, Dana 300TC, Dana 30 / AMC 20, True trac w/ 4.10s. 33" All terrains Blue and rust colored.
Rep Power: 9 Flex BT is on a distinguished road
I got fed up with my Weber 34dgec (discontinued re-branded solex piece of junk) and bought the weber 38 dges. Installation was going swimmingly until it came time to hook up the throttle. The 34 dgec (installed by the previous owner) replaced the stock throttle linkage bracket that mounts on the intake manifold with a little bracket that relocated the throttle cable to the other side of the carb. Going with the 38 assumes I have the original assembly and has stopped me in my tracks. Does anyone know where I can get the linkage bracket that will work with the 38? I looked all over for a stock replacement and couldn't find one anywhere Here's a picture of where I believe the stock bracket mounts.
Default Re: Throttle linkage bracket - weber 38 install help needed
Old 10-08-2016, 08:31 PM   #2
incardinate is offline
incardinate
Vehicle(s): '85 CJ7, 258, T4, D300
Rep Power: 0 incardinate is on a distinguished road
Sorry to dig up a 4 year old thread, but I'm having the same issue, what did you end up doing to find one? get lucky at a pull your parts?
Old 10-09-2016, 10:22 AM   #3
Rep Power: 23 Petescj is on a distinguished road
I'm pretty sure I have what you need. Pm me a pic of it just to be sure
Pete
Old 10-10-2016, 03:29 AM   #4
gert is online now
wow such a shame that no one responded to the OP if Pete dosent have it Collins bros should have it
Old 10-11-2016, 08:25 PM   #5
incardinate
I checked Collins Bros and didn't see it, but that site is an awesome resource! thanks for pointing it out to me.
Old 10-11-2016, 08:57 PM   #6
gert is online now
Call them they sell used parts as well, probably will be high priced just to warn you, Dennis has to pay for all trips around the US with Gas Monkey
Old 10-12-2016, 04:35 PM   #7
Flex BT is offline
Flex BT
Hey here I am!
I think I ended up having to take the bracket from the 34 and turning it upside down & backwards, then moving the little knob around on the throttle on the carb. If you still need help I can try to snap a picture when I get home.
Old 10-12-2016, 06:01 PM   #8
steve1973 is offline
steve1973
Vehicle(s): 1973 CJ5 258 CI, 2005 Ford F150 FX4 5.4L, 2010 Mazda CX9 AWD
Rep Power: 10 steve1973 is on a distinguished road
I did the same thing. Used the 34 bracket upside down and bent it to work.
Old 02-14-2017, 10:29 AM   #9
Chipw is offline
Chipw
Vehicle(s): 1980 CJ7. Iron Duke 4cyl., SR4, Dana300, Dana 30 with aussie locker, AMC 20 with detroit locker and 4.88 gearing, welded and trussed axle housing, one piece axles. 33x12.5 tires
Rep Power: 0 Chipw is on a distinguished road
I am about to drop a rebuilt Iron Duke into my 1980 CJ7. I was initially going to replace the carb with the weber 32-36 but after reading a little bit on the weber 38, i may go that route.
Im not finding much info on this carb other than this thread. Does anyone have any comments about the weber 38, either positive or negative?
Thanks,
Chip
Old 02-14-2017, 10:49 AM   #10
Flex BT is offline
Flex BT
After messing with both the 34 and 38, don't go down that road. The 38 has the same problems that make my Jeep stink like gas when you let off the throttle and my wife hates riding in it and therefore resents my second love. Don't be like me, buy a Holly. Everyone who has one loves and recommends it. I wish I could go back in time.
Also, I had to send my first 38 back and just recently had a starting issue due to the throttle plates sticking.
bracket , install , linkage , needed , throttle , weber
Throttle bracket Germy Drivetrain 6 02-19-2013 10:11 PM
CJ7 Throttle Linkage on Weber DGAVE 32/36 AKR Misc CJ Discussion 0 09-30-2012 10:55 AM
Throttle control linkage issue PetesJeep Drivetrain 2 05-05-2012 02:25 PM
77 CJ5 4.2l throttle cable bracket wrg Drivetrain 11 05-03-2012 07:37 PM
Weber throttle linkage help! Dan86CJ7 Drivetrain 5 01-28-2012 10:21 AM
