Default Th400 no 3rd gear
Old 05-02-2018, 07:50 AM   #1
Beyond low or burnt fluid is there anything else I can check for ( without dropping the transmission) that would keep the TH 400 from shifting into 3rd gear? I know there's vacuum lines and I believe a module of some sort. The front axle had lock out hubs installed but I don't know if there was an actual part time kit installed or not. I'm not sure how to determine that either. Anyway of figuring that out as well would be helpful. It's a '79 304 / TH400/ 1339 combo with the 4 low reduction.
Default Re: Th400 no 3rd gear
Old 05-02-2018, 11:17 AM   #2
mriplaybass is offline
mriplaybass
mriplaybass's Avatar
Check the vacuum lines from the engine to the modulator for loose or leaking connections. The modulator itself could be bad. I believe on the TH400, the modulator is located near where the dip stick goes into the transmission. Before replacing the modulator, I would check the shift linkage adjustment. You may be out far enough that the shifter is only allowing the transmission to go into 2nd.
The Following User Says Thank You to mriplaybass For This Useful Post:
Petescj (05-02-2018)
Old 05-02-2018, 02:04 PM   #3
Thank you. The module or lines to and from it seems to be the popular opinion of others I've asked as well. I tried slow moving the linkage while I was driving but it went quickly into neutral.
Old 05-02-2018, 04:35 PM   #4
mriplaybass
Take a look at the linkage where it attaches at the transmission. Note the position with the gear shift in park. Then disconnect the linkage at the transmission shift arm and see if the lever will go any farther to it's lock point. If it does, adjust the shift linkage to match the transmission lever with the transmission in the park position. I don't recall what the cable adjustment looks like, but how to adjust it should be obvious. Usually similar to adjusting a manual transmission's free play. (a cable going through a bracket with an adjustment nut and a jamb nut)
Petescj (05-03-2018)
Old 05-03-2018, 06:48 AM   #5
I was under it last night just out of curiosity. There is a vacuum line hanging right by the module but I couldn't feel anywhere to hook it up. There is a Hardline that is connected to the module. I have to get the pressure washer out and give it a good cleaning this weekend cause it's a mess right now.
I also noticed the hard lines going to the radiator are extremely close to the headers. I can't get my index finger between the two. That's alot of heat. I believe they should be above or at least beside the starter not under it. Once I get it cleaned up this weekend I'll take plenty of pics.
Old 05-03-2018, 07:24 AM   #6
gr8dain is offline
gr8dain
Vehicle(s): '84 CJ-8
Rep Power: 11 gr8dain is on a distinguished road
Pete, on our old impala, here is the modulator with the vacuum line attached. Then it goes up and connects to the back of the carb, if I remember correctly.
Not sure yours is the same, but hope this pic helps
Old 05-03-2018, 07:31 AM   #7
gr8dain is offline
gr8dain
There is obviously a hard line after the hose and then another hose connecting it to the back of the carb.
We had to replace our modulator last year. Our shifts were horrible. And then with the new one, we had to adjust it with a screwdriver, turning the screw inside where the hose connects to the modulator. I think counterclockwise softened the shifting.
The Following User Says Thank You to gr8dain For This Useful Post:
Old 05-03-2018, 09:15 AM   #8
Do you remember how much it was? I tried AutoZone site but I must not be using the right term in the search
Old 05-03-2018, 09:23 AM   #9
gr8dain is offline
gr8dain
I got mine at advance and can search it by Transmission Vacuum Modulator. I think mine was $20 or less. I did bring my old one in to make sure I got the right one. The first one I picked up was for a th350 and would not fit.
Old 05-05-2018, 12:38 PM   #10
Peanut Butter is offline
Peanut Butter
Peanut Butter's Avatar
Images: 37
Pete, be sure to check your linkage too. You can remove the connection at the transmission and turn it by hand. It should go from park all the way to 1st gear. The linkage on these column shifters are really bad about not working properly. The biggest culprit is the grommet located on the frame that the linkage depends on to keep the last part of it level before turning the knob on the transmission.
Hope this helps some.
The Following User Says Thank You to Peanut Butter For This Useful Post:
Petescj (05-07-2018)
3rd , gear , th400
Distributor Gear / Cam Gear Reality Check 007 Drivetrain 19 07-14-2017 06:32 PM
Th400 ? Peanut Butter Drivetrain 4 07-26-2013 07:38 AM
TH400 and 232 PCJ Drivetrain 3 07-09-2012 09:59 AM
gm th400 luv2ply2ns Drivetrain 1 05-26-2012 02:38 PM
th400 questions dudekcj7 Drivetrain 1 07-08-2011 10:40 AM
