Default Th400 ?
Old 07-21-2013, 09:09 AM   #1
Peanut Butter is offline
Peanut Butter
Peanut Butter's Avatar
Images: 37
I have a 1979 CJ7 I6 with a TH400. On the right side near the top of the case is a small tube that looks like wire insulation without the wire. Is this a vent? If not what is it? Any suggestions on how to improve it to keep water out? Thanks, Rod
Default Re: Th400 ?
Old 07-21-2013, 10:57 AM   #2
csuengr is offline
csuengr
Vehicle(s): 1980 CJ-7 LT1 TF727 NP231-D300 Waggy D44's ARB's 35" tires
csuengr's Avatar
Rep Power: 9 csuengr is on a distinguished road
That should be a vacuum line for the E-drive vacuum motor on the transfer case.
Default Re: Th400 ?
Old 07-22-2013, 08:18 AM   #3
Peanut Butter
Images: 37
No. I know all about those lines. This is on the automatic transmission case, near the top, right hand side, and close to the engine block. There is an indentation in the transmission case where this comes out. Rod
Tried to insert a picture, but not having much luck.
Default Re: Th400 ?
Old 07-23-2013, 07:09 PM   #4
Shifter is offline
Shifter
Vehicle(s): 83 CJ7 310" tuned port sm465 trans dana 300
Rep Power: 8 Shifter is on a distinguished road
Yes that is the transmission vent. You could put a large vacuum line on it and run it up the firewall then put a vent cap on it.
Default Re: Th400 ?
Old 07-26-2013, 07:38 AM   #5
Peanut Butter
Images: 37
Shifter, Rod
th400
TH400 Automatic ZionJeeps Drivetrain 6 02-07-2013 08:12 PM
TH400 removal in a 77 CJ7 skillet62 Drivetrain 5 12-16-2012 07:14 PM
TH400 and 232 PCJ Drivetrain 3 07-09-2012 09:59 AM
gm th400 luv2ply2ns Drivetrain 1 05-26-2012 02:38 PM
dead TH400 trw Drivetrain 6 09-26-2009 10:47 AM
