Default Tera flex 4:1 low gear set
Old 12-30-2018, 09:39 PM   #1
my86cj7 is offline
my86cj7
Vehicle(s): '86 CJ7, 400, SM465, D300, D44, D44
Rep Power: 0 my86cj7 is on a distinguished road
Hello, I am changing out my transmission to a Sm465 and keeping the Dana 300 transfer case. I am looking to rebuild the Dana 300 and looking to purchase the 4:1 low gear set. Is it worth it or overkill for my project 86 Cj7 jeep.
Default Re: Tera flex 4:1 low gear set
Old 12-30-2018, 09:48 PM   #2
That would depend on your plans for your Jeep. If you plan on running tuff trails then yes but it is going to be mainly a street driven with some lite trail use than no.
Old 12-30-2018, 10:00 PM   #3
gert is online now
I wonít know for sure for a few more months if it was worth it ( Iím sure it is tho) but the JB conversion gear set is better than the terra low set itís a one piece gear versus terra low two piece
I rebuilt my 300 with everything JB conversion sells for it, so I have their gear set, sliders 32 spline front and rear output with 1350 yokes, also the rotation ring with the extended input shaft
https://www.jbconversions.com/products/dana300/
Also JB custom makes the best twin stick I have ever seen
https://www.amazon.com/JB-Custom-Fab...SIN=B000FPYAAG
The Following User Says Thank You to gert For This Useful Post:
my86cj7 (01-02-2019)
Old 12-30-2018, 10:08 PM   #4
coldair is offline
coldair
coldair's Avatar
Images: 44
All the JB customs stuff is awesome wish I could afford what you did.
Old 12-30-2018, 10:11 PM   #5
gert is online now
I was working a lot of forced overtime back then, when I got the parts they looked so awesome I left them on the table a few weeks before I installed them
Oh ya I forgot their instructions are second to none I had a pretty thick book by the time I finished printing out their install manuals
Old 12-30-2018, 10:50 PM   #6
If you are going to do trails like the Rubicon and Dusy, then it would be worth it. Keep in mind that with that kind of gear reduction, there will be a tremendous amount of torque put out and you could wipe out a gear set by pushing it too hard. On a longer trail, you will be shifting in and out of the lower range as when going thru the easy stuff. In 4th gear/low range you will be traveling quite slow to get to the next tough spot. I would advise a good shifter like the JB. When I bought mine it was before similar kits were available.
Old 12-31-2018, 04:21 AM   #7
One of the best mods I ever did to my Jeep.
flex , gear , low , set , tera
T-18a or any rebuild kit and Terra Flex? Hedgehog Drivetrain 48 05-26-2016 02:50 PM
Flex fan Germy Drivetrain 13 06-07-2013 01:23 AM
4.0 EFI Flex Plate to TH400 machinedog Drivetrain 0 04-14-2010 01:17 AM
Tera Flex Guide Im Not Spam Jeep News and RSS feeds. 0 12-14-2009 05:41 PM
Flex OIIIO CoreyYoungCj577 Suspension and Steering 20 12-08-2009 05:04 PM
