Default T-18 reverse lock-out
Old 04-15-2012, 05:52 PM   #1
Cascade Cruiser is offline
Cascade Cruiser
Vehicle(s): 1974 CJ5 (current) 258 I6, T-18, D-20, D-30, D-44 1975 CJ5 304 V8, T-15, D-20, D-30, D-44, Renegade, Levi Edition
Cascade Cruiser's Avatar
Rep Power: 0 Cascade Cruiser is on a distinguished road
Hello to everyone and thanks for the help in advance. New to the forum experience so here goes. I did do a search and found one thread a few months old but no reply so I thought I'd start a new one.
Just bought a 1974 CJ5, 258 I6, T-18 4spd. The shifter has alot of slop in it and there is no reverse lock-out. Without care you can try and shift straight into reverse from second or from fourth when down shifting. Really horrible sounds. Don't care for it.
How easy is it to replace the spring? Is there anything else besides the spring that "might" need replacing? Does the tranny need to be removed or can it be done with the tranny in place?
Default Re: T-18 reverse lock-out
Old 04-16-2012, 01:20 AM   #2
Saddle Tramp is offline
Saddle Tramp
Rep Power: 11 Saddle Tramp is on a distinguished road
There are lots of parts to wear in the top cover that could be causing a sloppy shifter like the the Trunnion pins. You can check them from the top side through the floor board cover BUT BE CARFUL TO NOT DROP THE PINS INTO THE CASE OR YOU’VE GOT BIG PROBLEMS. There is no true “lock out” for reverse it is a feel that you should develop.
Old 04-16-2012, 09:38 AM   #3
Sasquach is offline
Sasquach
Sasquach's Avatar
Images: 35
Rep Power: 13 Sasquach is on a distinguished road
Shifting the T-18 can not be rushed, funny post by ? a few years back said they are like driving an old farm truck.
Old 04-16-2012, 10:46 AM   #4
MN CJ7 is offline
MN CJ7
Banned
Vehicle(s): 1978 CJ7 Silver paint with black hard top on 33" radials & eagle alumium rims. Good looking ride and have done lots of work to make it look and run great. Stock equipment is 258 carb, power brakes, power steering, hard top & hard doors (per vehicle gross weight) tilt steering wheel, big brake package with large rotars & drums, T18 Trans with low 6.4 granny gear, Dana 20 transfer, Dana 30 front axle, Dana 44HD rear axle with 3.73 gears. True Trac ft & rear. I was around jeeps in the 70's and drove a 1973 Jeep Truck. My family had 4 jeeps at the time. We also joined a jeep club back then too. So about 6 years ago looked for a Jeep CJ and found the vehicle above.
Rep Power: 0 MN CJ7 is on a distinguished road
The t18 shifter can get wear and get sloppy
Advance Adapters.... sells new shifter and some part to replace/install... last time I looked, yr ago, they were about $55 plus shipping.... might be worth a look.
Better lube will help quite a bit too.... eps with the hd truck trans like t18.... Try the Amsoil MTF, Manual Transmission Fluid, in the t18 and transfer case.... you will be amazed how much better the jeep trans shift with the MTF.... Sells for 9-12/quart if look around a bit
I put a GL5 gear lube in my T18 in a few months it was starting to fail and did not work well.... Correct lube makes a huge difference..
my t18 shifts similar to reg trans
Amsoil MTF has all the jeep trans listed on the back by number, t18, t4, t5 etc
Old 04-18-2012, 04:21 PM   #5
Cascade Cruiser
Thanks for the thoughts but the tranny shifts smoothly enough, the problem is the reverse "lock-out" or "gate". There is none.
If, from second gear, you do your "up-over-up" to third you should come up against some sort of resistance before where more pressure to the right will allow you to move the gear shift over far enough to allow you to then move the gear shift up, or forward, into reverse. There is absolutely no way to tell if you're near third or reverse the way it sits right now.
Also, going from fourth gear to second there is no way to know, with any certainty, if you're headed towards second or reverse. With 20 minutes of driving you do get used to it and can make repeated shifts without grinding gears.
Regardless, there is something missing or broken and I would like to know if anyone has had this problem and how difficult it is to fix?
Old 04-18-2012, 08:11 PM   #6
defibvt is offline
defibvt
Vehicle(s): 1974 CJ5, 232 (overhauled with larger cam and bored out to .30),T-18 w/ granny gear, Dana 300 w/ Lomax 4:1 gears.
defibvt's Avatar
Rep Power: 10 defibvt is on a distinguished road
You might try giving these guys a call Novak Jeep Conversions - Home . They can probably help you obtain a correct answer.
It's not about flexing in a CJ it is about hang time.
lock-out , reverse , t-18
Shaking in reverse blaylock6502 Drivetrain 2 04-27-2012 12:06 PM
Reverse light Germy Chassis and Body 5 08-31-2011 08:27 PM
T18 reverse switch help CJ007 Drivetrain 6 07-26-2011 10:30 PM
Reverse lights always on ColoradoCJ7 Chassis and Body 8 03-08-2011 03:27 AM
Reverse Shackles kickitandholdit Suspension and Steering 16 12-20-2010 04:12 AM
