I've got an 82 CJ7 and it's been V8 swapped by the PO. I'm now doing a Hamilton FI conversion and the instructions call for a 3/8" feed line and 1/4" return. My sending unit appears to have 1/4" ID feed & 3/16" ID return hard lines coming out of it, if I'm measuring correctly. I am assuming the ID is where I should be measuring this.
The Jeep obviously came with the 258 6 cylinder so that explains the small line sizes. I have the plastic gas tank, a 21 gallon I think?
Is there a source for a replacement sending unit with the larger size lines or will I need to modify mine, or just swap to an earlier V8 style tank/sending unit?
