Default Soft Pedal
Old 10-30-2013, 04:28 PM   #1
Tin Medic is offline
Tin Medic
Vehicle(s): 85 CJ-7 Renegade: Fuel Injected 4.2L I6/T5/D300 D30 with ARB Air Locker, AMC 20 w/Posi Warn 8000 LB winch VIAIR Onboard Air System 33x12.5x15 Goodyear MT/R's Kenwood head Unit Hella E-Code Lights
Tin Medic's Avatar
Rep Power: 8 Tin Medic is on a distinguished road
Have a soft pedal that goes to the floor when I step on it. I have to press it several times to get braking power. I am not losing fluid and there is no booster. It seems to be worse in stop and go traffic. Ideas?
Default Re: Soft Pedal
Old 10-30-2013, 04:39 PM   #2
Rep Power: 19 Old Dog is on a distinguished road
master cylinder leaking past seals, or air in system. That's all I can think of.
Old 10-30-2013, 07:29 PM   #3
Tin Medic
Tin Medic's Avatar
I am leaning in that direction also. Found some fluid leaking down the inside of the firewall.
Old 10-30-2013, 07:32 PM   #4
harleydragon is offline
harleydragon
Vehicle(s): 80 cj7 w/ not even stock 350,350 turbo tranny,208 t-case,dana 60 front,14 bolt rear..nothing on this jeep is stock.. 80 cj7 w/nearly stock 350,350 turbo tranny,divorced 68 gmc t-case and dana 44 front,12 bolt rear... 91 jeep yj wrangler w/4.0,auto,stock axles,soa
harleydragon's Avatar
Rep Power: 7 harleydragon is on a distinguished road
master cylinder
Old 10-30-2013, 09:04 PM   #5
Tin Medic
Tin Medic's Avatar
I have a TJ master cylinder and power booster in the shop, guess I know where its going.
Old 10-30-2013, 09:18 PM   #6
harleydragon
fittings on the lines will probably be different
Old 10-30-2013, 09:36 PM   #7
ThisGuyUKnow is offline
ThisGuyUKnow
Vehicle(s): 1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG Honda vtx1800c
ThisGuyUKnow's Avatar
Rep Power: 12 ThisGuyUKnow is on a distinguished road
will that fit? I have a cj power booster and master.Just pulled from.my Laredo
1986 CJ7 Laredo- 4.0,NV3550,D300,AMC20 3.31
2002 Honda VTX 1800C, 2006 F150 Supercrew 4x4
Old 10-31-2013, 06:19 AM   #8
it might have metric fittings so you might have to change your fittings out on your lines the power booster will sure feel better
pedal , soft
Gas pedal replacement. InfidelOffroad Chassis and Body 2 06-17-2013 07:56 PM
CJ5 Gas Pedal Sensitivity bdowns Misc CJ Discussion 5 01-14-2013 12:36 PM
Soft Brake Pedal. csuengr Suspension and Steering 22 10-22-2012 08:51 PM
Brake pedal pad browndog314 Introductions 4 01-05-2012 12:43 AM
gas pedal mylittlecj5 Chassis and Body 7 02-01-2011 07:37 AM
