Default So what's the preferred method for
Old 03-09-2020, 06:23 PM   #1
Project86 is offline
Project86
Vehicle(s): 1986 CJ 7 Blue 2004 Chevy LWB CC, 2012 Corvette Grand Sport 1986 CJ 7 Red Garnet 1978 CJ 7 Kinda Orangish
Rep Power: 10 Project86 is on a distinguished road
rebuilding the front hubs? I got ol' standard Dana 30 front axle with 6 bolt locking hubs. Is there is rebuild kit for these (if there is I haven't found it yet)? Or is it easier to buy a prepackaged 5 bolt hub and swap it over to my 6 bolt?
Default Re: So what's the preferred method for
Old 03-09-2020, 08:53 PM   #2
Just buy a set of Milemarker Hubs and life will be good.
The Warn OEM hubs are junk....
Gary
Patrick (03-11-2020)
Old 03-10-2020, 04:34 AM   #3
Scout1067 is offline
Scout1067
Scout1067's Avatar
Images: 3
I essentially rebuilt my OEM hubs last year but had to buy most of the parts separately. I got most of what I needed from Torque King at pretty reasonable prices.
https://torqueking.com/
Old 03-11-2020, 05:57 PM   #4
Patrick is offline
Patrick
Patrick's Avatar
ďOr is it easier to buy a prepackaged 5 bolt hub and swap it over to my 6 bolt?Ē
You canít put a 5 bolt locking hub on a 6 bolt hub assembly. You will need the older and better 6 bolt locking hub. Bolts have a tendency to loosen on either style, but there are ways to address this issue.
Old 03-13-2020, 09:18 PM   #5
Project86
My bad, let me be more clear on the "swap". As my research seems to indicate the internal parts are all the same on certain hubs can be gutted and used in my 6 bolt hubs. At this point, I most likely will buy the MM and either use 'em as is or gut 'em and use my original hubs.
method , preferred
Easiest bushing removal method ever gert Chassis and Body 4 06-13-2019 05:48 PM
