Default reverse grind?
Old 01-24-2010, 08:58 PM   #1
cjnewbie is offline
cjnewbie
Vehicle(s): 79 cj7 360 3 speed
Images: 16
Rep Power: 11 cjnewbie is on a distinguished road
so i finaly got the motor done and in the jeep lastnight and got to drive it for the first time today ,but reverse seams a little crappy if you put it in gear realy slow it grinds some but if you just put it in it seams ok is the reverse gear a straight cut gear and is this part of the grinding or is it just worn ? other than that i love my first jeep !!!!!!!!
Default Re: reverse grind?
Old 01-25-2010, 07:17 AM   #2
Images: 220
What trans? On my T15 in my CJ I just got into the habit of putting it in 1st, then reverse. Also, double clutching helps too...
Old 01-25-2010, 07:31 AM   #3
cjnewbie is offline
cjnewbie
Images: 16
it is the three speed sorry not sure of the number still learning all the jeep stuff
Old 01-25-2010, 07:49 AM   #4
Images: 220
No problem, what year? The T15 was used from 71 - 75. The T150 76 - 79.
Old 01-25-2010, 08:24 AM   #5
cjnewbie is offline
cjnewbie
Images: 16
man see so much to learn LOL ya it is a 79 cj7 now with a 360 and the three speed also any idea what gear ratio would have been stock in mine or atleast the most common? now that i know every thing seams to work i plan to pull the diff covers this weakend to change fluid and check things but just wondering what should be in it
Old 01-25-2010, 03:04 PM   #6
Images: 220
It could be just about anything - probably a 3.31, 3.54 or right around there. Unless you can find the build sheet you never know what was in it, and since you have a 360 - you never know what may have been swapped. There may be a stamping or a tag on the diff also.
When you put the cover, just look for a number like 4313 (3.31 ratio) or 3911 (3.54 ratio). This the number or teeth on the ring gear (43) and the number on the pinion (13).
43 / 13 = 3.31
Old 01-26-2010, 11:46 PM   #7
biohazard cj is offline
biohazard cj
Vehicle(s): 78 cj 5
Rep Power: 11 biohazard cj is on a distinguished road
Send a message via AIM to biohazard cj
i have the same grinding unless i put it in first then reverse.
how do you know what tranny you have?? i was told it was a t18 idk tho.,
i do know i have a 4 spd granny 1st, and it looks like it has a pto cover?
grind , reverse
Shaking in reverse blaylock6502 Drivetrain 2 04-27-2012 12:06 PM
T-18 reverse lock-out Cascade Cruiser Drivetrain 5 04-18-2012 08:11 PM
Clutch grind Flex BT Drivetrain 8 03-17-2012 10:19 PM
Reverse light Germy Chassis and Body 5 08-31-2011 08:27 PM
T18 reverse switch help CJ007 Drivetrain 6 07-26-2011 10:30 PM
