Question Recipient of Prior Dauntless Conversion in CJ5
Old 03-22-2020, 02:24 PM   #1
ttkent is offline
ttkent
Vehicle(s): 1969 CJ5, 225ci, T90, D18, D27, D44
Rep Power: 0 ttkent is on a distinguished road
I am in the beginning stages of the restoration yet, my 1969 CJ5 appears to have left the factory with a 4 cylinder and sometime over the years the Buick V6 was 'installed'. Upon removal of the tub, it further evidenced some of what I would consider 'jerry-rigging', i.e., motor mounts, clutch control, etc...I purchased new engine mounts from Advanced Adapters and am currently in the process of determining the best fit with respect to clearances. I've bolted one of the mounts to the engine and and attached the bracket (see pic) but, when the bracket is placed one way it projects beyond the bottom of the frame and when turned 180, it projects beyond the top of frame.
My initial thought was to rely on the transmission/transfer case mount at the crossmember as my fixed point and work from there to place the engine mounts however, I've read that shifting the entire assembly forward may be a better bet. I hope to speak with someone who has already been down this road and, perhaps, would be willing to answer a few questions.
Also, I would like to properly identify the bell housing and whether or not it's the correct one to use in this application.
Default Re: Recipient of Prior Dauntless Conversion in CJ5
Old 03-23-2020, 11:24 AM   #2
hagar is offline
hagar
Vehicle(s): 47 CJ2A 225V6 SM420 D18 w/Warn overdrive D30 5:38 Power Lok D44 5:38 Flanged Detroit Locker
Rep Power: 10 hagar is on a distinguished road
If it were me, I would source the factory V6 frame mounts from a donor frame.
This would also allow the use of factory motor mounts.
I've never liked the AA mounts, function nor appearance.
Bellhousing appears correct; adapter appears home made.
Swing on over to ECJ5.
Lots of knowledge over there for earlier Jeeps.
cj5 , conversion , dauntless , prior , recipient
What to do with a Dauntless 225... redbo Drivetrain 10 04-30-2017 07:32 PM
Dauntless HEI ? chipdom Drivetrain 15 06-01-2014 10:22 AM
Dauntless kadar Drivetrain 1 03-22-2012 01:29 PM
304 vs Dauntless dave123 Drivetrain 20 04-01-2010 07:52 PM
crappy headlights?? h4 conversion or hid conversion biohazard cj Chassis and Body 6 12-14-2009 08:54 AM
