Default Pulling D44 axles
Old 03-22-2019, 06:27 PM   #1
cglax6 is offline
cglax6
cglax6's Avatar
All,
This weekend I was planning on installing my rear disc kit. I pulled the drums off and removed the nuts holding the axle, tube, and backing plates together. I was under the assumption that it wouldn't take much effort to pull the axles out of the tubes. I have a '76 CJ5, but the axle is most definitely a D44. I can't see behind the seal, so I have no clue what the issue is.
Did the D44s have c-clips? If not, what do you think is going on?
I can't install the disc brakes until I get these axles out.
Any insight is appreciated.
Sent via Google translate using braille through Tapatalk
Default Re: Pulling D44 axles
Old 03-22-2019, 06:48 PM   #2
cglax6 is offline
cglax6
cglax6's Avatar
Pics of what I have going on.
Old 03-22-2019, 07:07 PM   #3
Posi is online now
Posi
Posi's Avatar
No C-clip
They have always popped out for me by tapping the flange with a rubber mallet.
I'm assuming you don't have a slide hammer?
They rent them for no charge at your local parts store.
Old 03-22-2019, 07:07 PM   #4
mriplaybass is offline
mriplaybass
mriplaybass's Avatar
It's been awhile, but as I recall, there is a pressed on collar (bearing retainer) on the axle shaft. The shaft has to come out with the bearing. It won't slide out of the bearing until the collar is removed, and you have to get the axle out to do that. Kind of looks like you just have a lot of rust holding the bearing in. Give it a good soaking with penetrating oil, and let it sit overnight at least. Then try a slide hammer to pull the axle.
Old 03-22-2019, 07:09 PM   #5
mriplaybass
Originally Posted by Posi View Post
No C-clip
Old 03-22-2019, 07:13 PM   #6
cglax6 is offline
cglax6
cglax6's Avatar
I picked up a slide hammer, and it's soaking in PB blaster.
Hopefully I don't destroy the out seal. I'll have to pull the bearings for that, right?
Old 03-22-2019, 07:29 PM   #7
Posi is online now
Posi
Posi's Avatar
I'm guessing that seal will leak if you try to reuse it.
While out replace the bearing retainer ring, bearing, and seal.
You'll need to notch the bearing retainer with a chisel to enlarge the bore to remove the retainer, bearing, and seal.
Or bring the shaft to a machine shop and have them do it.
Old 03-22-2019, 07:39 PM   #8
cglax6 is offline
cglax6
cglax6's Avatar
My neighbor has a home garage to die for...and he has a long bearing puller and a press. I'm guessing I'll need to replace the bearing race in the axle tube as well.
Appreciate all the insight.
Old 03-22-2019, 07:51 PM   #9
mriplaybass
Since the bearing retainer is a pressed on collar, I would replace everything. It's a real hassle to have to split the retainer off if something goes bad.
Old 03-22-2019, 07:56 PM   #10
Posi is online now
Posi
Posi's Avatar
Yes, race comes with the new bearing.
axles , d44 , pulling
Pulling wire driver007 Chassis and Body 18 03-03-2015 11:26 PM
full size axles vs. widetrack axles cj7pimp Drivetrain 12 05-16-2013 02:10 PM
Pulling 360 Germy Drivetrain 29 09-19-2012 05:44 AM
pulling my rear axles rr41mag Drivetrain 2 06-01-2012 09:10 AM
pulling the motor drivert51 Drivetrain 14 04-03-2012 08:51 PM
