Default Pilot Bushing (first post)
Old 11-03-2016, 08:25 AM   #1
Ibluckyjoe is offline
Ibluckyjoe
Vehicle(s): 85 CJ7 Laredo, T5, D300, 258
Rep Power: 0 Ibluckyjoe is on a distinguished road
Hello and thank you for facilitating this.
I have installed now two pilot bushings from two separate clutch kits from different manufacturers. On the second one I verified fit on transmission and alignment tool prior to installing. Fit beautifully. After install, not so much. Guide shaft is now .015 inches larger than the hole. So, the install is compressing the bushing too much.
Anyone else had such an issue? Anyone have the correct specs for the pilot bushing? I still have the original as chewed up as it from removal I suppose NAPA can still identify?
Thanks in advance.
Default Re: Pilot Bushing (first post)
Old 11-03-2016, 12:54 PM   #2
Neuner is offline
Neuner
Banned
Vehicle(s): "Oscar":1985 CJ7, 4.0 '98 OBDII, T177, RE 4.5" lift w/ CV Jnts, Dana 300, Dana 30 and AMC 20, 33" BFG KO2s, Raptor Lined Interior and Rustoleum BBQ exterior.
Rep Power: 0 Neuner is on a distinguished road
When I did my tranny swap, T5 to T177 with the 258, I had the same problem. None of the kits nor the individual recommended bushings fit. I believe both input shafts are the same BTW. I went to Advanced Auto and found a pilot bearing that worked great. I don't have record of the model # but it looked like this one:
National Needle Bearing FC-66426: Advance Auto Parts
The one I got had an ID of 0.591 but don't recall or have noted what the outside needed to be. It had puller notches in it like the link.
The Following User Says Thank You to Neuner For This Useful Post:
Ibluckyjoe (11-04-2016)
Old 11-03-2016, 04:09 PM   #3
Lots of folks 'knock' the bearing. I've used one for 12+ yrs now with no issues.
Just make sure you add some grease after installing the bearing.
HINT: A socket turned around, makes a great tool for seating a pilot bushing or bearing.
Old 11-03-2016, 08:52 PM   #4
Ibluckyjoe
Thank you very much. That appears to be the same exact bearing I picked up today. I was worried about the bearings holding up but 12 years is plenty good for me!
Old 11-03-2016, 09:02 PM   #5
mstar is offline
mstar
Vehicle(s): 1969 cj5 v6 2004 tj sahara 1971 cj5 renegade II
mstar's Avatar
Rep Power: 8 mstar is on a distinguished road
If you have access to a dial indicator I would check for alignment between crankshaft centerline and the bellhousing opening.Very important and easy to do.Full instructions on Lakewood or other scattershield manuf. sites.
I indicate all mine before assembly. mike
Member of Salem Jeep Club / PNW4WDA
Old 11-04-2016, 10:51 PM   #6
Ibluckyjoe
Pleased to report the transmission is seated. Both clutch kits from NAPA and Oreillys have the incorrect bushing. The NAPA bearing they show and sell stand alone, fits just fine.
bushing , pilot , post
Which pilot bushing? Rollie Drivetrain 3 11-02-2012 04:51 PM
Pilot Bushing Lubricating Wick ??? billyocup Drivetrain 5 03-23-2012 09:41 PM
pilot bushing to bearing swap chooch Drivetrain 2 06-19-2011 10:38 AM
Pilot Bushing revisit tvince Drivetrain 2 04-10-2010 09:19 PM
Pilot Bushing size question tvince Drivetrain 2 04-04-2010 10:56 AM
