Default Oil Pump Pressure Valve Spring
Old 12-12-2017, 09:32 PM   #1
notwaiting is offline
notwaiting
Vehicle(s): Blue 1980 CJ5, T18 4-speed, 258 six cylinder, Detroit Locker front, Stock AMC rear.
Rep Power: 0 notwaiting is on a distinguished road
I have a 1980 CJ with a 258 six (which I am replacing). New 258 six cylinder engine came without the nipple to install the spin on oil filter. Sent the old core back for refund before I noticed, now I do not have a means to install the oil filter.
Found the nipple at Summitt. (yaaay)
Next thing......
The engine rebuild manual shows a pressure release valve, spring and a retainer that goes into the block at the filter location and they are not on the new block either.
Question: Since new oil filters have the pressure valve buit-in is the spring valve and retainer needed anymore?
Default Re: Oil Pump Pressure Valve Spring
Old 12-15-2017, 06:50 PM   #2
notwaiting
Found information that the oil bypass valve, spring and retainer must be installed on the new block.
Does anyone know of a vendor or an individual that might sell these?
bypass , oil , pressure , pump , spring , valve
Valve spring and valve cover hitting glenn56 Drivetrain 1 04-17-2016 06:15 PM
Oil pressure relief valve cap help Jimbos76cj Drivetrain 0 12-27-2015 09:12 AM
Oil pressure relief valve Germy Drivetrain 7 12-19-2013 10:59 AM
No fuel pressure - anything other than the pump? Flex BT Drivetrain 6 12-05-2012 08:42 PM
power steering pump pressure tmkyle Suspension and Steering 0 08-03-2010 11:40 PM
