Default New speedo gear
Old 04-21-2018, 11:47 AM   #1
tahoe is offline
tahoe
Vehicle(s): 81 CJ7, 304 transplant with OEM SR4, Dana 300 T-case, AMC 20 rear and D30 front. Factory hardtop, factory A/C
Rep Power: 0 tahoe is on a distinguished road
Good morning all ! Ok I have the CJ back finally with new G2 one piece axles and 3.73 gears. I am running 31 BFGs and as yall know the speedometer is like, WAY off. I have a new speedo gear on the way so here is my question:
How difficult really, is it to swap this in ?
From what I have seen and read on line it appears simple. I have a dana 300 with the long tail. So just undo the lock bolt and retainer, pop out the housing, remove the old gear, insert the new gear.
What about clocking the new gear to match up with markings on the housing ?
Then pop it back in ?
Default Re: New speedo gear
Old 04-21-2018, 01:56 PM   #2
I have switched out a few speedo gears and it sounds like you have described it pretty correct. Once I switched gears and the speedo did not work, so I just took it out, rotated it and had good results. You might find a few tips by doing an internet search.
The Following User Says Thank You to Torxhead For This Useful Post:
tahoe (04-23-2018)
Old 04-21-2018, 07:07 PM   #3
OP-You're on the 'rite' track.
tahoe (04-23-2018)
Old 04-23-2018, 03:22 AM   #4
tahoe is offline
tahoe
Thanks guys !! The new gear should be here tomorrow so,,,,, asap i will update eveyone.
Old 04-23-2018, 06:02 AM   #5
Images: 220
Your will do well, just unbolt the small housing, pull off the old gear and replace... Good to go!
gear , speedo
speedo gear jeeper1 Drivetrain 6 04-22-2015 05:04 AM
Need help figuring out what speedo gear to order cuban11182 Drivetrain 1 03-30-2014 11:20 AM
Speedo Gear Help Holmes 78 Drivetrain 2 02-17-2014 10:55 PM
Speedo gear in transfer case Mick Drivetrain 3 02-10-2013 02:03 AM
Updaged gear ratio calculator with a speedo gear calculator derf Drivetrain 5 09-21-2011 03:28 PM
