Default Need advice on an engine please
Old 09-28-2019, 12:04 PM   #1
TnCJ is online now
TnCJ
TnCJ's Avatar
Rep Power: 2 TnCJ is on a distinguished road
My 1980 Jeep's engine is getting tired. Slight knock on the bottom end, almost zero oil pressure at idle and 15 lbs running down the road. [and yes LG I verified pressure with another gauge lol] Sooo, I think its time for a rebuild. But after some searching I've found another CJ5 that was going through a frame off resto but the owner has decided to go another route.
This Jeep is a 1978 model and the engine has been rebuilt as well as the rearend. Owner says they have run engine and has 60 lbs oil pressure 124 lbs compression. .002-.003 clearance on crank and rods. Has a stage 2 comp cam, keith black pistons, and a light weight crank [not sure what the light weight crank is?]
It has a 3 speed tranny, and not sure about the xfer case so if I do purchase it i'll be putting my T176 tranny and 300 Xfercase on it. Also comes with new clutch, pp, throwout bearing. flywheel etc.
Only thing I am really concerned about is the power steering pump is on the passenger side and the alternator is on the drivers side. Which is opposite of what mine is. Would that be a big problem? Would it be possible to switch sides without too much problems?
Any advice you guys could give would be greatly appreciated.
BTW he is selling the whole shebang at a very reasonable price, cheaper than what I could have just my engine rebuilt.
Thanks again!!
Default Re: Need advice on an engine please
Old 09-28-2019, 10:20 PM   #2
RiverandSand is offline
RiverandSand
RiverandSand's Avatar
As long as both motors are the same 6cyl.(258) you should be able to transfer all of your accessories over to the new motor. The 78 if stock will have a Dana 20 transfer case and T150 3spd. Sounds like a good deal.
The Following User Says Thank You to RiverandSand For This Useful Post:
TnCJ (09-29-2019)
Old 09-29-2019, 07:03 AM   #3
TnCJ is online now
TnCJ
TnCJ's Avatar
Thanks, I appreciate it.
I don't need the T150 or the Dana 20 but it comes with the deal.
The compression seems a little low but the motor has only been run for 20 minutes or so on a stand so i'm thinking the rings haven't had time to seat fully yet.
I think i'm going to jump on it if it's still available.
advice , engine
New engine, any advice mstevens61 Drivetrain 5 03-10-2019 04:41 AM
Engine Assembly Lube Advice during Rebuild DBCJ Drivetrain 19 04-01-2014 05:08 PM
Intake Manifold adapt....need some advice tech advice please. jade1076 Drivetrain 4 08-06-2013 07:34 PM
Need advice on engine rebuild jeepboy45 Drivetrain 5 05-28-2012 02:34 PM
Engine upgrades, advice please! cdlongjr Drivetrain 23 04-28-2009 07:29 PM
