Default MSD blaster coil popped
Old 01-15-2020, 07:27 PM   #1
Basod is online now
Basod
Basod's Avatar
Went to orient the Jeep under my lifting beam in preps to tear down the bottom end - no spark.
I just put a new dizzy in and set timing last week it was running fine. Was looking around and noticed everything kind of wet thought it was condensation as itís really humid.
Then a checked the wetness- itís a light oil. Look a little closer and the top of the coil is popped. Installed back in September/October. Only other thing Iíve done to affect it recently was remove the ballast wire
Default Re: MSD blaster coil popped
Old 01-15-2020, 08:37 PM   #2
Wow thatís a trip
Old 01-15-2020, 09:53 PM   #3
R717 is online now
R717
Vehicle(s): 86 CJ-7, 258, junkyard HEI, Weber DGEV, T5, D300, D30/D44, OME YJ lift springs, BFG 33x12.5 A/Ts
R717's Avatar
Rep Power: 0 R717 is on a distinguished road
Originally Posted by Basod View Post
Only other thing Iíve done to affect it recently was remove the ballast wire.
There's your root cause. I had the same result years ago after bypassing a failed ballast resistor.
Old 01-16-2020, 01:08 AM   #4
First one I've seen.
Been run'n a MSD ign and coil for over 15 yrs now.
Gary
Old 01-16-2020, 11:28 AM   #5
Basod is online now
Basod
Basod's Avatar
Yeah that's the first thing I assumed, though I was assured in the Team Rush upgrade the ballast wire could be eliminated.
Some web research claims that rotor phasing and poor ground from head to block can cause the coil to absorb the spark energy and overheat.
Ballast wire has been removed for a couple weeks but maybe 70-80 miles and some idling time while setting timing.
I'll double check all the ignition wiring and verify its not some intermittent deal where my ignition is not shutting off.
We'll see if NAPA honors a replacement on it
Old 01-16-2020, 03:11 PM   #6
JeeperChris is offline
JeeperChris
JeeperChris's Avatar
I have exactly 12.0 volts at my coil. What is your reading at the positive post?
Old 01-16-2020, 07:07 PM   #7
Basod is online now
Basod
Basod's Avatar
Just a shade under battery voltage 12.3. It was 5.75 with the ballast wire. I never checked when running but Iíd assume 13.8 alternator voltage.
Ordered a new high vibration coil, be interested to see how warm it gets.
Old 01-17-2020, 10:09 AM   #8
R717 is online now
R717
R717's Avatar
You may have to compare the resistance values on the primary side of both coils. The original coil may be ok while the msd flows too much current.
For context, my experience was with points on a sbc. I had the dwell maxed out for the most rpm potential.
blaster , coil , msd , popped
PIAA lens popped off Turbogus Misc CJ Discussion 3 04-25-2014 04:42 PM
Msd 6al.. What coil to run. Jimbos76cj Chassis and Body 2 10-18-2013 12:07 PM
MSD Blaster Coil Dirt Works Drivetrain 4 01-08-2013 07:40 PM
Blaster 3 with Stock Module? viking4949 Body, Electrical, Chassis 2 05-04-2012 11:12 PM
new coil? Berg Drivetrain 1 02-22-2010 12:42 AM
