Default Motor mount cracked - suggestions for replacements?
Old 04-07-2012, 08:46 PM   #1
Flex BT is offline
Flex BT
Vehicle(s): 1981 CJ7. I6, Weber 38/38 with TEAMRUSH upgrade. T5, Dana 300TC, Dana 30 / AMC 20, True trac w/ 4.10s. 33" All terrains Blue and rust colored.
Rep Power: 9 Flex BT is on a distinguished road
One of the motor mounts on my I-6 has a crack along the side of it. The engine shakes, just a little bit, and I'm hoping replacing the mount will resolve the issue (I'm also hoping it might resolve the transmission chatter).
I just looked at quadratec, they have a bunch of different mounts from $25 to over $80. If I'm just looking to do some normal off road stuff (no crazy rock climbing or anything) what would be a good set of mounts to get?
Default Re: Motor mount cracked - suggestions for replacements?
Old 04-07-2012, 08:52 PM   #2
Cheepjeep85 is offline
Cheepjeep85
Cheepjeep85's Avatar
Rep Power: 13 Cheepjeep85 is on a distinguished road
poly mounts are the best, but if you replace them with poly make sure to use the same on the transmission mount to. i've heard you can crack the tranny if you dont, or maybe its don't use the poly tranny with rubber motor. either way its probably a good idea to replace em all at the same time.
Old 04-07-2012, 08:54 PM   #3
Images: 220
If the mount your talking about is the factory rubber one, just go to your local auto parts store and pick it up, I would replace both at the same time though.
Old 04-07-2012, 09:26 PM   #4
I just did mine and got them from NAPA. Thats all you need.
Old 04-07-2012, 09:28 PM   #5
Flex BT is offline
Flex BT
Not worth the extra bucks for the poly?
I figured I'd do the transmission mount at the same time. Can I use the same jack-plus-lumber method to get that in?
Old 04-07-2012, 10:05 PM   #6
73CJ is offline
73CJ
73CJ's Avatar
Images: 61
Rep Power: 13 73CJ is on a distinguished road
Ditto cheapjeep.
I used to knock holes in my oil filter with the rubber ones. It was the travel limiterplate you need with the rubber mounts that actually punched the hole in it. Not even close with poly mounts. Maybe a little noise, but hey it's a Jeep.
Old 04-08-2012, 10:00 PM   #7
Flex BT is offline
Flex BT
My jeep has a big suspension lift. How can I tell if it has motor mount shims? Will it just look like an extra piece under the motor mount? Are they solid metal and can be reused?
Default
Old 04-08-2012, 10:02 PM   #8
Cheepjeep85
Originally Posted by 73CJ View Post
Ditto cheapjeep.
Well mine still has rubber mounts that's all my budget would allow when I built my motor. They work fine just waiting on one of em to crap out then I'm going all poly. You know the old saying, if it ain't broke don't fix it.
Droooiiddd 2
Old 04-08-2012, 11:18 PM   #9
73CJ is offline
73CJ
73CJ's Avatar
Images: 61
They look like the plate under these mounts. They are a separate plate.
Old 04-09-2012, 10:47 AM   #10
Incommando is offline
Incommando
Incommando's Avatar
Rep Power: 9 Incommando is on a distinguished road
Although better with the I6 then a V8, the CJ motor mounts are notoriously weak.
I used M.O.R.E. Bombproof mounts.
Jeep Motor Mount for CJ-5, CJ-7, CJ-8 with AMC 6 CYL.Engines from Mountain Off-Road (M.O.R.E.)
cracked , motor , mount , replacements , suggestions
258 motor mount question Farmfunder Drivetrain 5 04-08-2012 10:15 AM
Exhaust-motor mount question suburban99 Drivetrain 1 03-04-2012 09:51 PM
motor mount spacers? Tony Marc Chassis and Body 3 09-22-2011 03:28 PM
Motor Mount replacement cheeky chops Chassis and Body 14 07-23-2011 07:50 PM
cracked motor mount bracket CJ777 Drivetrain 13 12-16-2009 11:05 PM
