Default markings on a ring gear
Old 02-03-2013, 06:09 PM   #1
rr41mag is offline
rr41mag
Vehicle(s): 04 dodge truck, 1966 chevy truck, 2012 rav4 And finally a 1981 jeep cj7 258 hardtop
Rep Power: 10 rr41mag is on a distinguished road
SO i decided to fix my rear end leak. "15 41 001 307" Was stamped on my ring gear. The housing has "AA" stamped on it. What does this mean?
Default Re: markings on a ring gear
Old 02-03-2013, 06:56 PM   #2
73CJ is offline
73CJ
73CJ's Avatar
Images: 61
Rep Power: 13 73CJ is on a distinguished road
I suspect the 15 41 is they are 2.73 gears.
The other may be a date code.
The diff brg caps should have stamps to match them to the side. See if AA is on one of the caps. Should be same side as the housing.
Old 02-03-2013, 06:59 PM   #3
rr41mag is offline
rr41mag
And I'm running 35" tires. No wonder it's kinda tuff taking off at a red light
Old 02-05-2013, 02:03 AM   #4
alabamaboy54 is offline
alabamaboy54
Vehicle(s): 1985 cj-7. 258 I6 T-176 w/ D300 D30/AMC20
Rep Power: 9 alabamaboy54 is on a distinguished road
This helps with the stampings on the outside of the differential
Jeep Axle: AMC 20
-appears to validate the 15 and 41 giving you the 2.73 ratio
Old 02-05-2013, 08:40 PM   #5
73CJ is offline
73CJ
73CJ's Avatar
Images: 61
But I bet you're hitting 100 wound out in 3rd !
gear , markings , ring
D30 ring gear torque specs Cheepjeep85 Drivetrain 2 11-23-2012 06:39 PM
Starter Ring gear dslywalker Drivetrain 14 05-04-2012 04:47 PM
Ring and pinion Germy Drivetrain 14 10-22-2011 08:43 AM
cj5 flywheel ring gear replacement rekocisko Drivetrain 5 07-01-2011 11:48 PM
D-ring isolators Petescj Chassis and Body 8 03-22-2009 12:10 PM
