Default Locker advice
Old 03-06-2018, 11:26 AM   #1
jmbridges is offline
jmbridges
Vehicle(s): 1981 cj7, amc 258, t176, Dana 30
jmbridges's Avatar
Rep Power: 0 jmbridges is on a distinguished road
I am now almost 2 years into my 81 cj7 rebuild, and it's coming along slowly but surely. Working on the rear axle now, installing moser one piece axles and I have started to think about the rear differential. I knew I was going to probably have to regear- original ratio was 2.73:1 - and with 33's that is not going to be drivable, unless the PO regeared when he put the 33s on. I didn't get to drive it long enough when I bought it to tell, though will see when I get in there.
Anyway, that got me to thinking about lockers as well.
I don't plan on rock crawling, just some routine off roading, maybe get into some mud now and then. This will also not be a daily driver, but i would like to take it out cruising from time to time.
From the research I have done on here and other places, it seems like a LSD might serve me best. I am thinking about the Detroit truetrac. Any thoughts about that vs a true locker? I don't think I want the expense and complexity of a selectable. Also, do I need both front and rear? Thanks much
Sent from my iPad using Tapatalk
Default Re: Locker advice
Old 03-06-2018, 01:31 PM   #2
jp360cj is offline
jp360cj
I've been very pleased with my Trutracs. You'll need a new carrier for the rear anyway, so that lowers the marginal cost of the TT.
As long as I keep the tires on the ground, they all pull. And it drives the same on the street.
Old 03-06-2018, 07:14 PM   #3
A 'locker' and an LSD are not the same.
FWIW: I've been very happy with my front and rear DL's.
Old 03-06-2018, 07:34 PM   #4
jmbridges
jmbridges's Avatar
Thanks for the replies! Yes, I know a locker and an LSD are different . That's part of the reason I need some advice - not sure which I need. Based on what I have read, LSD seems like it might be better for what I need, but I'm a newbie, so WTH do I know. Just wanted some real world advice on both. LG, how are the roads manners with the DLs? Is yours a DD? I take it from both your replies that having front and back is a good idea?
Sent from my SM-N950U1 using Tapatalk
Old 03-06-2018, 08:03 PM   #5
Yes a DD. The rear DL has a quirks for sure and after 25 plus years of have'n it in, I don't even think about it. In a tight turn, the DL 'drives' from the inside wheel so a 'chip' of the tire is kinda normal.
I do get reminded after my wife or kids drive it on the street....LOL
If I lived in snow country, I would have installed Power-Loc LSD, front and rear.
Old 03-07-2018, 09:04 AM   #6
HackFabrication is offline
HackFabrication
Vehicle(s): 1976 CJ5, 2020 Grand Cherokee Summit, 2018 GMC Sierra 1500 SLE Regular Cab Shortbed
Rep Power: 12 HackFabrication is on a distinguished road
Originally Posted by jmbridges View Post
...not sure which I need. Based on what I have read, LSD seems like it might be better for what I need, but I'm a newbie, so WTH do I know. I take it from both your replies that having front and back is a good idea?
IMHO: On a Jeep CJ that will see no street snow/ice, the Detroit lockers would be fine. If you are willing to accept the 'quirks' that LG stated. If you put a Detroit locker in the front, don't run on hard pavement with the front hubs locked.
I run ARB's front/rear in my 76 CJ5, because I want the road manners of open differentials, with the capability to fully lock either front, rear, or both when necessary.
The one piece axles are a definite 'must'. I have Moser's in my AMC20. I would also recommend welding the axle tubes to the housing.
"In the end...It's all Hack."
Old 03-07-2018, 12:10 PM   #7
elkgroveguy is offline
elkgroveguy
Vehicle(s): 1979 CJ5 258 (with Howell fuel injection) T-18 4 speed Dana 20 T-case
elkgroveguy's Avatar
Rep Power: 0 elkgroveguy is on a distinguished road
If money is no object I like Electric lockers front and rear.
When on a budget I go (lunch box locker in the front) True trac in the rear.
I have had both and for those are the best for street manners in my opinion.
Old 03-07-2018, 07:37 PM   #8
gr8dain is offline
gr8dain
Vehicle(s): '84 CJ-8
Rep Power: 11 gr8dain is on a distinguished road
Aorry to jump in with a question, but I have a lunch box locker and wondered if I should put it in the rear or not. As a DD, is that going to be bad? A lot of clicking as I drive and chirping around corners? Any other drawbacks?
If I just have the one locker, and it is a lunchbox, should it go in the front? I do hit the trails a couple of times a year and run blues but want to do more rocks. AND still use it as a DD. Thanks for your thoughts.
Old 03-08-2018, 11:31 AM   #9
Posi is offline
Posi
Posi's Avatar
Do you have stock 2 piece rear shafts?
If so I would install the locker in the front.
If the answer is no, I would install it in the rear.
When you climb offroad all the weight is in the rear where a locker would help.
You have a long wheel base Jeep your not going to feel much.
My 77 CJ7 has spartans front and rear and the only time I feel the rear is backing up while turning sharp and once in awhile slowly turning going forward.
Although a lot of highway driving, I ran it from Colorado Springs to Ouray (about 5.5 hours) last year without any locker issues. I will again be running it from Colorado Springs to Moab next month.
I feel the Detroit more in my short nose 71, but still not bad enough that I would change it.
Old 03-08-2018, 12:51 PM   #10
gr8dain is offline
gr8dain
Thanks. I have 1 piece axle shafts in the rear. So I will continue with my plan of throwing it in the rear.
advice , locker
Locker ID help Flex BT Drivetrain 10 01-03-2017 05:25 PM
Intake Manifold adapt....need some advice tech advice please. jade1076 Drivetrain 4 08-06-2013 07:34 PM
ARB Air Locker Promotion, Buy air locker & get a FREE air compressor Morris4x4Center Great Deals! 0 03-01-2013 04:35 PM
Do I have a locker? hopefulcj Drivetrain 7 08-31-2011 08:42 AM
D44 locker priceg Great Deals! 0 01-06-2011 10:49 PM
