Default Intake Manafold Holes
Old 10-15-2019, 07:06 PM   #1
CFCA is offline
CFCA
Vehicle(s): CJ7
Rep Power: 0 CFCA is on a distinguished road
This is my first post. I look forward to learning from all of you!
A quick question. I recently purchased a 86 CJ7. The engine was running rough, is a pain to start (starter fluid gets it going) and you would need to keep a higher rpm otherwise it would putter out.
As i stared cleaning up the engine, it became very clear that there are 3 threaded holes in the intake manifold that were left WIDE open by the previous owner - clearly some sensor was removed, never replaced and is allowing air to flow in downstream of the carb.
Has anyone ever plugged these up? I can literally stick a screwdriver into the manafold. Could this be the cause of my issues?
Default Re: Intake Manafold Holes
Old 10-15-2019, 07:49 PM   #2
Sure could. Can you post pics of the manifold?
Old 10-15-2019, 07:55 PM   #3
TnCJ is online now
TnCJ
TnCJ's Avatar
Rep Power: 1 TnCJ is on a distinguished road
Not familiar with a 1987 Jeep but unplugged holes in the intake side of the manifold would definitely be a huge problem. It would make it run much to lean.
Are the holes threaded? If they are get some plugs and plug them up and see if that helps.
Pics would help identify the problem.
Welcome to the site!!
Old 10-15-2019, 09:07 PM   #4
JeeperChris is online now
JeeperChris
JeeperChris's Avatar
Rep Power: 1 JeeperChris is on a distinguished road
Could this be a model that used a water jacket to heat the underside of the carb? Maybe they are just holes for water hoses.
Old 10-16-2019, 07:30 AM   #5
CFCA is offline
CFCA
Vehicle(s): CJ7
Here you go!
Old 10-16-2019, 11:31 AM   #6
JimsCJ5 is offline
JimsCJ5
Vehicle(s): 1979 CJ5 Renegade 258, t-18 pretty much stock except for a later model aluminum intake manifold and Gronk 2150.
Rep Power: 7 JimsCJ5 is on a distinguished road
Put your thumb over the holes while running or cranking. If there is vacuum, plug them. I'd probably plug them anyway just for looks/peace of mind.
Our Build thread: http://www.jeep-cj.com/forums/f98/fa...project-23905/
Old 10-16-2019, 11:45 AM   #7
JeeperChris
Here is what it should look like:
https://www.ebay.com/i/372744505313?...iABEgIVy_D_BwE
The Following User Says Thank You to JeeperChris For This Useful Post:
Petescj (10-16-2019)
Old 10-16-2019, 01:48 PM   #8
Originally Posted by JeeperChris View Post
That's a good pic. Everyone who responded to this thread has an earlier version of that manifold with less junk. 😂
Old 10-16-2019, 01:55 PM   #9
yellow85cj is offline
yellow85cj
Vehicle(s): 85 CJ7, 258,4.0 head, T177, D300, Dana 30, AMC 20, 3.54
Images: 3
Rep Power: 11 yellow85cj is on a distinguished road
Here's a pic of the sensor holes.Don't understand why you don't have coolant flowing out as two of the sensor holes have coolant flowing through them. The knock sensor is dry and not needed if you aren't using the computer.The only switch you should run is the manifold heater sensor. It turns the manifold heater on/off when the engine is cold. Manifold heater is on the bottom of the intake under the carb. Warms the fuel/air as it flows past.
I used the coolant temp switch for a manual temp gauge.
The hole on the top of the intake that is circled is the input side of the coolant, coming from the water pump, there is a similar hole on the rear of the intake that is where the coolant exits the intake and goes to the heater core. The coolant then comes out the heater core and runs back to the water pump.
The Following User Says Thank You to yellow85cj For This Useful Post:
Old 10-16-2019, 02:03 PM   #10
This is the old style manifold. You don't have any coolant leaks? Sorry I see Yellow 85 beat me to it
holes , intake , manafold
Jerry Can Holes JeepCJ5 Chassis and Body 3 12-01-2016 01:54 PM
Dana 20 what goes in these 2 holes? duke94 Drivetrain 6 12-04-2013 12:47 PM
Holes in floor pan jb8376 Chassis and Body 7 12-03-2013 10:20 AM
Fix Them Holes MDJEEPER Chassis and Body 36 03-22-2010 09:49 PM
