Default Identifying gear ration
Old 03-10-2019, 02:00 PM   #1
Masscj7 is offline
Masscj7
Images: 10
Did some searching on the site and the web and I知 scratching my head. On my Dana 30, one full revolution on my wheel, I知 getting one and a quarter turns out of my pinion gear. That seems like an ultra high gear ratio. What am I missing?
Default Re: Identifying gear ration
Old 03-10-2019, 04:59 PM   #2
RiverandSand is offline
RiverandSand
RiverandSand's Avatar
There might be a tag on one of the bolts on cover with the ratio. If not check the rear diff for a code stamped on the right axle housing near the cover. Both ratios should be the same.
On edit the codes can be found on jeeptech.com look under amc 20 axle tab.
Old 03-10-2019, 06:26 PM   #3
IF it's still the OEM ratio-Most likly 2:73 or 3:31.
Pull the diff cover-The ring gear will have it stamped on it.
You sure your rear axle is not a '44'? Many '86s were.
Old 03-10-2019, 06:49 PM   #4
He was talking about the front.
Old 03-10-2019, 07:19 PM   #5
Masscj7 is offline
Masscj7
Images: 10
Lumpy, I wish I had a 44, but unfortunately I have a 20.
But was talking about the front. I did find these markings on it this evening.
Old 03-10-2019, 09:03 PM   #6
coldair is offline
coldair
coldair's Avatar
Images: 44
Your Jeep has 2.73 gears
Old 03-10-2019, 11:24 PM   #7
jp360cj is offline
jp360cj
Yep, 49/18= 2.72s
When doing the tire to driveshaft rotation on an open diff, you need to make sure both tires are turning at the same speed. Best way is to roll the tires across the ground. If only 1 tire (or axle shaft) turns, you need to do 2 complete tire rotations. I learned that the hard way after a buddy passed up what turned out to be 3.54 WT axles because we couldn't figure out the ratio
Old 03-11-2019, 01:28 PM   #8
2:73 ratio.
Copy on the '20'-I have seen many who 'thought' they had a '20', when in fact it was a '44'..........
gear , identifying , ration
Help with identifying a V6 in a mid 60's CJ5 SactoGunSmoke Drivetrain 8 03-08-2017 02:50 AM
Help identifying this bracket. GlennMcD Chassis and Body 6 06-03-2014 10:13 PM
Identifying an Axle . Miles Drivetrain 6 03-10-2013 02:11 AM
Need help identifying lift busterswt Suspension and Steering 7 11-10-2012 07:47 PM
Need help Identifying sbrodacz Drivetrain 11 04-21-2010 01:03 PM
