Default Howell TBI Dies in 4th Gear
Old 09-17-2019, 04:42 PM   #1
jzak is offline
jzak
Vehicle(s): 1981 CJ5/258 4.2L I6, Tremec T-176 4-speed, Dana 300, Power Steering, Howell Throttle Body Injection System, Warn Locking Hubs, Warn Rock Crawler front/rear bumper with Tire Swing Carrier, Full Roll Cage, Pro Comp ES9000 shocks
jzak's Avatar
Rep Power: 6 jzak is on a distinguished road
Hey Guys,
So I've had this issue since i bought my CJ5. I can accelerate 1st through 3rd gears fine, but when i get to 4th gear, if i push the pedal too far the engine starts to die on me.
These are the following things i've done to try to fix the problem:
1: Replaced all the sensors (O2/MAP/TPS)
2: NEW PCV/Idle Air control valve
3: Bought a rebuilt TBI unit
4: Bought a NOS ECM (switched out the CJ chip)
5: Ran a new return line (5/16th hose) directly to the return port on the tank.
6: Replaced Fuel Pump and Filter multiple times.
7: Checked all the vacuum lines
I'm at my wits end here. Any help would be appreciated.
Best,
Josh
Default Re: Howell TBI Dies in 4th Gear
Old 09-17-2019, 07:31 PM   #2
Posi is offline
Posi
Posi's Avatar
Do you mean you swapped the old chip into the NOS ECM, or switched out the CJ chip for a new one?
Did you have a PSI issue or just thought it would help? What was your return PSI, before then after install of the new return line?
Same question, did you have a PSI issue or just thought it would help? What was your feed PSI, before and after install of the new pump and filter?
Before I bought any parts I would have taken a log of the block learn numbers without the log your working blind when it comes to FI. I'm not saying its fuel related, but I would start there after a full tuneup.
A $50 ALDL cable (or you can make your own for $5), old laptop, and free online program.
4th , dies , gear , howell , tbi
Anyone in here good with gear swaps? Gear pattern help request! OldsCool Drivetrain 9 02-20-2019 11:46 AM
CJ dies, can't go higher than 3rd gear savscj7 Drivetrain 5 01-30-2017 09:22 PM
...it just dies every now and then hdgapeach Drivetrain 4 02-02-2015 08:51 PM
Jeep dies when i shift into gear yetiwarrior82 Drivetrain 6 04-25-2012 10:52 AM
dies lastseen Drivetrain 5 04-28-2011 10:12 PM
