Default Good Replacement Master Cylinders
Old 10-11-2019, 09:10 PM   #1
Super8mm is online now
Super8mm
Vehicle(s): 1980 CJ5, 4 cyl, Borg Warner/Ford SR-4 4 spd, Dana 300 transfer case. Start a heart transplant mid November with LS1 and SM465 :-)
Super8mm's Avatar
Rep Power: 2 Super8mm is on a distinguished road
I lost my brakes today and of course I am 350 miles from home.
First thing I checked we the fluid level and all there was in there was rust. I made it to a parts store and got a bottle of fluid and filled it up and I can pump them up enough for this weekend and then tow it home behind my motorhome.
what are some good replacement brand or ones to stay away from. I does have SS lines already but the fluid looks like hot chocolate after pumping the brakes up I will have to flush all the lines.
Default Re: Good Replacement Master Cylinders
Old 10-11-2019, 09:56 PM   #2
hole is offline
hole
hole's Avatar
Images: 28
Rep Power: 12 hole is on a distinguished road
Always have had good luck with Napa
The Following 2 Users Say Thank You to hole For This Useful Post:
Lumpy Grits (10-11-2019), Super8mm (10-12-2019)
Old 10-11-2019, 10:19 PM   #3
Super8mm
Super8mm's Avatar
I will have to call them, all they show on their web site was rebuild stuff
Old 10-12-2019, 12:15 AM   #4
Belizean is offline
Belizean
Belizean's Avatar
X2 on the NAPA. Probably most are rebuilt these days where ever you get one
Old 10-12-2019, 09:49 PM   #5
Steve Neul is offline
Steve Neul
Vehicle(s): 1975 Jeep CJ5 with a 258 inline six engine. I believe the transmission and transfer case are original to the jeep.
Rep Power: 0 Steve Neul is on a distinguished road
I replaced mine in 1998 with a Napa master cylinder and I'm still using it.
The Following User Says Thank You to Steve Neul For This Useful Post:
Super8mm (10-14-2019)
Old 10-14-2019, 10:29 PM   #6
Super8mm
Super8mm's Avatar
Has anyone had to flush their brake system?
after I put brake fluid in and drove it the fluid looks like chocolate milk.
If you have how did you do it, just pull fresh fluid through unit it comes out clear?
Old 10-15-2019, 09:37 PM   #7
Steve Neul
The cleanest way to change the fluid would be with one of those brake bleeding tools where you can catch the fluid. If you don't mind the mess you could open the wheel cylinder valves and pump the brake pedal until you get all of the old fluid out.
Super8mm (10-15-2019)
Old 10-15-2019, 10:26 PM   #8
Super8mm
Super8mm's Avatar
I do have a mighty vac that would work IF I can get the bleeder valves open, if not I will have to pull the cylinder and probably cut the line off??
Old 10-16-2019, 07:54 AM   #9
hole is offline
hole
hole's Avatar
Images: 28
Worst case is vice grips on the bleeder if it strips with a wrench. Try using a line wrench, it can help minimize stripping. A trick I use on underbody bolts and nuts is to tap the wrench with a hammer, tightening direction first, then try and loosen it. PB Blaster ( or the like) can help too.
The Following User Says Thank You to hole For This Useful Post:
Super8mm (10-16-2019)
Old 10-18-2019, 02:16 AM   #10
mdeluca is offline
mdeluca
mdeluca's Avatar
Rep Power: 4 mdeluca is on a distinguished road
I'd never buy a remanufactured master cylinder again.
I purchased a new MC from Napa and recommend.
NMC M2506 (Manual Brakes)
NMC P2506 (Power Brakes)
MY BUILD THREAD --- www.1986jeeprestoration.blogspot.com
The Following User Says Thank You to mdeluca For This Useful Post:
Super8mm (10-18-2019)
cylinders , good , master , replacement
Instrument panel light sockets - found good replacement hollasboy Chassis and Body 2 12-07-2018 02:36 AM
What is a good junkyard replacement for front seats and slider track for a cj7 Garymyers3 Chassis and Body 10 10-11-2017 01:57 PM
How Many Cylinders Do You Own 73CJ Sand, Dirt and Mud 33 12-13-2014 08:22 AM
Tips on Master Cylinder Replacement 007 Chassis and Body 7 02-06-2014 07:43 AM
Found a great article bout brake master cylinders BajaEdition Suspension and Steering 1 05-31-2010 02:41 PM
