Default Fuel tank sending unit
Old 08-09-2019, 08:06 PM   #1
weithman5 is offline
weithman5
Vehicle(s): 84 cj-7 renegade (original owner)
Rep Power: 4 weithman5 is on a distinguished road
Original tank and I plan on removing the old sending unit to put in a new one with electric fuel pump. Does that large plastic nut hold everything in? Any tips and is it worth replacing those rollover vent check valves?
Default Re: Fuel tank sending unit
Old 08-09-2019, 09:00 PM   #2
TnCJ is online now
TnCJ
TnCJ's Avatar
Rep Power: 1 TnCJ is on a distinguished road
Yes the large nut holds everything in. Pretty sure it just turns like a quarter turn. Been a long time since i've fooled with one.
The Following User Says Thank You to TnCJ For This Useful Post:
weithman5 (08-09-2019)
Old 08-10-2019, 12:51 PM   #3
lowcountry is offline
lowcountry
Vehicle(s): '83 CJ7, 258, D30, amc 20, D300, 4sp, '70 Z28, LSX, 6sp, 711 fwhp (N/A), 2015 2500 HD Duramax/Allison
Rep Power: 1 lowcountry is on a distinguished road
I just replaced mine. Yep what he said, pretty straightforward. If you buy the kit, it comes with a new nut and o-ring. I did not replace my vents because they looked happy. I replaced all the hoses too. Damn mice built a condo on top of the tank and feasted on the fuel line and ate through the sending unit wires also...
If you don't know where you're going, any road will do...
Old 08-10-2019, 12:56 PM   #4
weithman5
Thanks and ouch. Squirrels chewed through my daughter's spark plug wires once....
Old 08-10-2019, 07:10 PM   #5
weithman5
What did you use for a wrench? I'm thinking an oil filter wrench but I will have to find one bigger than what I have.
Old 08-10-2019, 07:41 PM   #6
weithman5
Buddy had a large wrench he used for hot tub plumbing. Lot of sludge after 35 years
Old 08-10-2019, 07:55 PM   #7
I use a strap wrench.
That's rust more than sludge.
Put some solvent in that tank along with a handful of marbles, and shake the crap out of it.
weithman5 (08-10-2019)
Old 08-11-2019, 07:37 AM   #8
lowcountry
That's ugly. I'm guessing you have been guessing how much fuel you had?
A pipe wrench works too...
Old 08-11-2019, 09:24 AM   #9
weithman5
Yes. But it has been a few years since its been driven. Complete restoration in progress. Make that slow progress.
fuel , sending , tank , unit
82 jamboree fuel tank and sending unit Skylerm727 Chassis and Body 7 08-20-2017 04:13 PM
In tank High Pressure Fuel pump Prototype Sending Unit ThisGuyUKnow Drivetrain 7 08-26-2016 01:45 AM
79 CJ5 Fuel Sending Unit Removal from Tank? Rexx66 Misc CJ Discussion 10 06-12-2014 08:04 AM
spare fuel tank sending unit jeepboy45 Drivetrain 1 01-18-2014 01:43 AM
Swapping fuel tank, sending unit...? coffman Misc CJ Discussion 28 06-23-2011 09:06 PM
