Drivetrain Engine, Transmission, Differentials, Transfer case, anything that makes your CJ go forward. |
Fuel return line & vac line routing 84 CJ7This is a discussion on Fuel return line & vac line routing 84 CJ7 within the Drivetrain forums, part of the CJ Forums category; I recently purchased a 1984 CJ7. 258 Inline 6, 4 speed manual transmission and am trying to sort out some ...
11-04-2019, 09:55 PM
Vehicle(s): 1984 CJ7, 258 L6 4 spd manual, recent purchase
1977 CJ7 304 V8, 3spd, sold.
Currently own;
2001 TJ Wrangler
2009 JK 2-door Wrangler
1972 FJ40 Landcruiser
2014 Toyota FJ Cruiser
2008 Nissan Pathfinder 4x4
2018 Nissan Titan 4x4
1928 Chrysler
1950 Plymouth
Other jeeps...
1995 Jeep XJ Cherokee sold
1996 Jeep Cherokee XJ sold
1987 YJ Wrangler sold
I recently purchased a 1984 CJ7. 258 Inline 6, 4 speed manual transmission and am trying to sort out some randomly routed or missing plumbing & wiring.
Looking for some pictures of a stock correct 84 CJ7 engine compartment to see where everything is supposed to be and for advice on the best reference to purchase.
What is the fuel return line routing supposed to look like?
I'm talking about the connection from the fuel filter to the long hard line at frame
The picture is the line that was laying in there but it doesn't seem to have any obvious path.
I also have a bunch of missing vacuum lines and wires, nothing attached to the air cleaner housing for example but multiple places for connections.
Any help would be greatly appreciated.
Thanks.
Cleg.
Re: Fuel return line & vac line routing 84 CJ7
11-06-2019, 04:16 PM
The fuel filter has a second 1/4" outlet that should be routed down to the DS frame that returns to the fuel tank - look near your clutch linkage.
Check the line on the frame is clear before hooking it up.
The filter should be rotated so the small outlet line is on top.
Most everyone here recommends moving the filter away from the current location do to drips/fire hazard over the exhaust manifold.
I ran mine over the top of the valve cover, keeping it mostly on the PS of the engine
As for the rest of the vacuum lines, unless all the other emissions stuff is still there or you need it to pass smog, just cap or plug them.
The Following User Says Thank You to Basod For This Useful Post:
11-06-2019, 06:08 PM
Vehicle(s): 85 CJ7, 258,4.0 head, T177, D300, Dana 30, AMC 20, 3.54
The clip at the lower side of the steel line bolts to the block low down. The steel tube runs up and over the intake then uses a hose to connect to the fuel filter. The long hose in your pic then connects to the steel return line to the tank.
The FSM for 84-86 CJ's is on line in a few places, won't have pics, but will have diagrams. Can't find the new link to "adventures under the hood" has waht all the stuff is with pics and where it hooks up to. Maybe some one else has the link.
Found the site, this will help as much if not more for electrical/vac as the FSM. Table of Contents
Are you going to "Nutter" (remove computer, bring back to pre 83 no emissions stuff) ?
11-06-2019, 11:16 PM
Currently own;
2001 TJ Wrangler
1928 Chrysler
1950 Plymouth
Other jeeps...
Thank you Yellow85CJ.
A picture is worth a thousand words.
I hadn't tried routing the formed steel line vertically down the side of the engine.
Thanks also for the tip on the FSM and the link.
I like the idea of removing the computer and whatever else I can to simplify the engine bay.
We have no emissions testing here in Tennessee yet to worry about.
Do you think I would I need to use a pre-1983 carburetor to eliminate the computer or could the Carter C2-BBD be tuned to run without it ?
Cleg
Thread Tools |
Display Modes |
