Default first post - where to start. bearing noise/motor - sounds like water pump
Old 06-19-2016, 11:12 PM   #1
loguvna is offline
loguvna
Vehicle(s): 1980 CJ 5 Golden Eagle, 258, AMC 20, Dana 30? tired. 1976 Triumph TR6 1994 Honda Accord 1988 Ford Escort 1999 Chevy Tahoe
Rep Power: 0 loguvna is on a distinguished road
CJ5 Golden Eagle, 1980 - stock, except for a 31 tires. needs alot, but runs, and is fun around the neighborhood. tired suspension and tires, and a few leaks. I have been driving it until I started to hear some bearing noise around the front of the motor - I don't think its motor, but probably water pump. youtube wasn't much help - just curious how hard to tackle. decent mechanical skill, and the part is 16 dollars?
258 6cyl motor, 4 speed, pw brakes, steering, and tilt. if that maters.
Default Re: first post - where to start. bearing noise/motor - sounds like water pump
Old 06-20-2016, 08:56 AM   #2
Well, at least you know where the general area of where the problem is. Sometimes you have to just have to tear into these things to find out. The simplest issue it could be would be the fan belt, moving next to a pulley. Wobbling the fan is an easy way the check the water pump bearing as there should be no play there, check the pulley the same way. Good luck and welcome to the forum.
Old 06-21-2016, 05:40 PM   #3
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
First off, where is richardson? It does make a difference. Basic question, have you checked your oil level. Have you checked the fluid level in your power steering pump? Then there is the fan clutch. A water pump will usually leak at least a little when it's going bad. One thing I strongly suggest. Try not get in the habit of just throwing parts at a problem hoping you'll find the culprit. Also, water pumps are relatively inexpensive, but $16 seems far to cheap. If you are going to spend the time to install a part get a quality part that will last a reasonably long time.
Old 06-21-2016, 05:50 PM   #4
My SWAG is either WP or alternator bearing. Do you have a fan clutch? Those bearings go bad also.
Take the belts off, and see how smooth each turns. If one feels a bit 'gritty'. That's the bad one.
Good luck,
Old 06-22-2016, 08:06 PM   #5
jdcaples is offline
jdcaples
Vehicle(s): J0M93ECxxxx J - Jeep 0 - Year 1980 M - 1980: 4-speed Manual 93 -Inches of Wheelbase? E - 4150# GVW C - 6 Cyl, 258 CID, 2 Bbl Dana 300, SR-4, stock and rusting; I'm the fourth owner.
Rep Power: 8 jdcaples is on a distinguished road
Just curious: If he's not talking about Richardson, Texas, but say Richardson, WA how does that make a difference?
BTW there are at least 14 US states and one Canadian Province with a city called "Richardson," so "where is Richardson?" is a completely valid question.
-Jon
Old 06-23-2016, 12:32 PM   #6
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
jdcaples - Exactly. If a poster is nervous about giving out his/her exact location it would be better to give the state they live in rather than the name of the town for the exact reason you mention. For example Richardson New York has far different environmental conditions than a Richardson Texas.
The Following User Says Thank You to Hedgehog For This Useful Post:
jdcaples (06-23-2016)
bearing , noise or motor , post , pump , sounds , start. , water
throwout bearing noise buzzardB Drivetrain 16 01-18-2015 01:48 AM
water pump pulleys for short 225 V6 pump oldjeeplady Misc CJ Discussion 1 06-24-2014 12:09 PM
225 oddfire crank bearing noise?? sad day... jwillys Drivetrain 10 06-11-2013 10:18 AM
Left turn throw out bearing noise nctom Drivetrain 14 08-10-2011 09:20 PM
