Default Engine Build Date Code
Old 03-16-2011, 10:45 AM   #1
chodette is offline
chodette
Vehicle(s): 1981 CJ-5 Renegade 304/V-8
chodette's Avatar
Rep Power: 10 chodette is on a distinguished road
I need some help with my engine build date code. We were told when my Dad bought me this Jeep that it had the original engine in it. When I bought the TSM, it said the build date code would be on a plate attached to the right cylinder head cover. Was not there....Well, since I got the body off I found the plate on the back of the left head cover and it says "011H11". If it was a 1981 engine it should start with a 5 according to the manual. So does a 0 mean it is a 1976? What a stupid place to put a build code....valve covers get replaced all the time. Is there anywhere else I can pull a number off the engine that will confirm it is a 76 or an 81?
Thanks guys!
The Following User Says Thank You to chodette For This Useful Post:
rivergoblin (12-24-2014)
Default Re: Engine Build Date Code
Old 03-16-2011, 07:06 PM   #2
hagar is offline
hagar
Vehicle(s): 47 CJ2A 225V6 SM420 D18 w/Warn overdrive D30 5:38 Power Lok D44 5:38 Flanged Detroit Locker
Rep Power: 10 hagar is on a distinguished road
Well, since there weren't any V8 CJs in California after 1980, we're left with three choices:
the V8 was swapped into the Jeep;
the Jeep is a 49 state CJ;
the Jeep isn't a 1981 model.
But, it's true, the V8 engine codes were on small tags attached to the front of the RH valve cover; so your valve cover has been swapped around.
As for the engine build date, who knows; that valve cover may not be from that V8 engine...
Is there a tag on the carb, assuming it's still the Motorcraft 2BBL ?
Old 03-16-2011, 07:32 PM   #3
I would suggest that perhaps the 0 is a 5 that was stamped off center??
this would make it a 304 that was put together on 11/11/81.
Old 03-16-2011, 07:46 PM   #4
chodette is offline
chodette
chodette's Avatar
Hagar-It is not a CA Jeep. I had it shipped here from Arkansas. It is a 49 State model. The Jeep is definately an 81, verified by all the VIN plates. Here is the tag on the carb (1DM2J):
And IO, here is the tag on the valve cover. Doesn't look mis-stamped
So what do you guys think?
Old 03-16-2011, 07:50 PM   #5
your right it does not look like a 5. Oh well, it seemed like a good idea.
Old 03-16-2011, 07:52 PM   #6
chodette is offline
chodette
chodette's Avatar
Would the "0" make it a 76....assuming they used an "0"?
Old 03-16-2011, 07:52 PM   #7
does your block have 304 cast into the drivers side over the motor mount??
Old 03-16-2011, 07:54 PM   #8
chodette is offline
chodette
chodette's Avatar
Yes....Are there no other numbers on the engine that would help with the year? Ridiculous it was put on a valve cover!
Old 03-16-2011, 07:55 PM   #9
76 was a 9
Old 03-16-2011, 07:57 PM   #10
chodette is offline
chodette
chodette's Avatar
So what was an 0? UGHHH! I need to figure out the year so I can get the right emission parts.
build , code , date , engine
Engine Build - Take #2 certifiablejeep CJ Build Forum 11 11-04-2013 05:00 PM
Engine Code Question thiswontbetooexpensive Drivetrain 7 11-30-2012 03:11 PM
engine build question jeepboy45 Drivetrain 8 09-03-2012 08:54 AM
Engine build Ironmerganser Drivetrain 13 07-28-2011 04:20 PM
360 mild engine build buechecj7 Drivetrain 3 06-29-2010 12:15 AM
