Default Re: EFI fuel pump location?
Old 02-03-2019, 02:01 PM   #21
Belizean is offline
Belizean
Belizean's Avatar
Originally Posted by Posi View Post
Yes, 1980 cherokee 20 gallon tank will fit perfect in a 76 and up CJ
For whatever reason I no longer see the photo of the tank I posted.
Interesting. Maybe I will go out and measure my 96 just for the heck of it. Didn't realize they were injecting those in 80
Old 02-03-2019, 03:17 PM   #22
Posi is offline
Posi
Posi's Avatar
First year FI for the Cherokee is 86 for 4cyl, and 87 for 6cyl.
Just add a gm fuel pump.
Belizean (02-03-2019)
Question Re: EFI fuel pump location?
Old 02-18-2019, 07:47 PM   #23
mmcrae418 is offline
mmcrae418
Vehicle(s): 1984 CJ7, 4.0 swap, AX15, D300
Rep Power: 0 mmcrae418 is on a distinguished road
Anybody know what setup to use with the stock cj tank to put the pump in the tank. I have an EFI 4.0 swap from a '94 YJ. The tank setup is kind of a mess. Is there a pump/sending unit that can drop into the stock 15 gallon cj tank? I don't really want to "Customize" the stock CJ sending unit and tank like it is now...when something eventually fails.
Old 02-19-2019, 10:25 AM   #24
PistolDave is offline
PistolDave
Vehicle(s): 1977 CJ-7 SBC 5.7 TBI, TH400, D300, D44 front, D44 rear, 4.56's Detroit / Truetrac, SOA, 35" MTR-K's, ------------86 CJ-7 258 - T5 - AMC20/D30 3.30 open f/r - Dana 300 - 2" BDS wrangler springs - 31x10.5 BFG ************* 83 CJ7 3.8L, T19 5.1:1, D300, D30/AMC20, 4.11's, Chevy TBI, OX lockers, OME 2.5" lift YJ springs, 33x10.50/15 KM3's, Lots of rust and zip ties.
PistolDave's Avatar
Images: 7
Rep Power: 7 PistolDave is on a distinguished road
In-Tank Fuel Pump Module - PA-Series
The Following User Says Thank You to PistolDave For This Useful Post:
gr8dain (02-19-2019)
Old 03-16-2019, 01:02 PM   #25
stinkfinger is offline
stinkfinger
Vehicle(s): 85 CJ-7, 401, NV4500, clocked D300, AMC20 w/shafts, D30, 4" lift, 33" BFG MTs, Warn 8K. Sniper EFI still in the box.
Rep Power: 0 stinkfinger is on a distinguished road
I just ordered one of these for my Sniper install...
https://www.novak-adapt.com/catalog/...cj-fuel-module
Old 03-16-2019, 01:05 PM   #26
gr8dain is offline
gr8dain
Vehicle(s): '84 CJ-8
Rep Power: 10 gr8dain is on a distinguished road
Originally Posted by stinkfinger View Post
I just ordered on of there for my Sniper install...
Nice. And not a bad price either.
Do you have baffles in the tank? Worry about running dry when off camber?
Old 03-16-2019, 01:22 PM   #27
stinkfinger
The EFI not installed yet, the pump is the last part I need. I had them "customize" it with a Walbro 255 LPH pump, so that order is taking longer (it comes with an 36 GPH Delphi pump that they would only say is sufficient for factory 6.0 LS swaps). That might have been fine for my 6.6L, but I didn't want to take any chances since it's built up a bit. I have the factory 20g tank, so no baffles and yes I'm a little concerned about starvation when the tank is low. I've read that there is a sump of sorts (low spot in the center of the tank) that mitigates the issue somewhat, but it's kind of an experiment as it stands. A surge tank would probably be my fallback plan.
Old 03-16-2019, 05:40 PM   #28
coldair is offline
coldair
coldair's Avatar
Images: 44
This is what going in my tank when I get around to pulling it again. I did a pump setup a lot like the Novak pump but used the stock pump out of a Cherokee.
https://liquidironindustries.com/Wal...k-Pickups.html
Old 03-17-2019, 12:24 AM   #29
coldair is offline
coldair
coldair's Avatar
Images: 44
You can also get them from this company too. We used these in the snowmobile industry in the fuel injected sleds.
https://www.autoperformanceengineeri...l/pickups.html
Old 03-18-2019, 08:44 PM   #30
mriplaybass is offline
mriplaybass
mriplaybass's Avatar
Rep Power: 7 mriplaybass is on a distinguished road
This is what we have in ours to solve the starvation problem. Never had a starvation problem even with just a couple gallons of fuel in the tank.
efi , fuel , location , pump
258 fuel pump not pulling fuel Essenjeep Drivetrain 1 10-04-2014 07:06 PM
Fuel filter location fuzzy Drivetrain 4 09-23-2012 10:20 PM
Fuel Pump Tin Medic Misc CJ Discussion 9 07-01-2012 06:04 PM
Fuel pump Nixon Drivetrain 3 09-02-2010 03:01 PM
Location for Fuel Pressure Regulator GOPDiesel Drivetrain 3 12-29-2009 03:05 PM
