Default Distributor gear
Old 08-05-2018, 09:47 PM   #1
smbundy13 is offline
smbundy13
Vehicle(s): 1980 CJ7, 258 I6, SR4, D300. Power steering, power brakes. Stock axles stock susp. Gentle rehab in progress.
Rep Power: 7 smbundy13 is on a distinguished road
Changing from normal 1980 distributor to a dui hei unit and everything i have read told em to change the original drive gear from the distributor to the new distributor. Well, when trying to do that, noticed the original gearís inside diameter is a little too big. It isnít a snug fit.
What do yíall suggest?
I have seen where people suggest buying a msd gear.
Any ideas?
Default Re: Distributor gear
Old 08-05-2018, 10:19 PM   #2
I think this more of a 304 problem not a 258 problem. But if I'm wrong I'm sure someone will let me know.
Old 08-05-2018, 10:36 PM   #3
There is a history of some of the aftermarket HEI distributors that were made in China had a gear that was harder than the cam gear it meshed with. This would cause the cam gear to wear out. At least that's what I have heard. I would think that a distributor gear with a DUI name on it would be made to the correct hardness. You could call them on this just to make sure.
Old 08-06-2018, 07:05 AM   #4
smbundy13
Thanks for the info. I will call dui today and ask.
distributor , gear
Distributor Gear / Cam Gear Reality Check 007 Drivetrain 19 07-14-2017 06:32 PM
HEI distributor gear question jeremy5780 Drivetrain 4 04-02-2017 01:56 PM
MSD distributor cam gear roll pin question mopar440cu Drivetrain 21 03-28-2016 08:51 AM
HEI Distributor gear question evesdropper Drivetrain 5 04-08-2015 01:48 AM
Question about DUI distributor gear DCJ79 Drivetrain 6 04-05-2012 08:32 AM
