Default Dana 300 upgrade questions.
Old 03-04-2020, 03:28 PM   #1
mattgunguy is offline
mattgunguy
Vehicle(s): 83 Cj5. 258 straight 6. T-176. Dana 300. Dana 30. AMC 20 (with locker). Named BJ 69 Cj5. Dauntless 225 v6. T-14. Dana 18. Dana 27 Dana 44. Named Kyzer.
Rep Power: 1 mattgunguy is on a distinguished road
So my little dana 300 t-case is still a bit of a mystery to me. I've never been inside one or really know that much about it. I'm far far more familiar with the NP205 / NP 203 & some Rockwell military monsters.
I'm building up the 83 cj5 into a bit of a do everything buggy. Not super great at any one thing, but competent at every thing. I realize this means compromise, & I'm good with that.
What's going on so far. Gots a 4" lift. Still on cj springs but will be yj or tj springs eventually (I get them confused). Putting in a dana 44 from a 72 cj this weekend. Wide track dana 30 up front (wheel spacers for the back axle). Regearing to 4:88 & a Grizzly locker in the rear. Running 33x12.50x15 for rubber. Thinking 35's next time around. Rebuilt the T-176 a few months ago. Will be swapping out the 258 l6 to a Dauntless 225 v6 in the next few months.
With that stuff in mind. What should be done to the dana 300? I've been searching here & elsewhere for answers. But that is a truly huge set of opinions right there.
Thanks for any input.
Default Re: Dana 300 upgrade questions.
Old 03-04-2020, 04:50 PM   #2
Basod is offline
Basod
Basod's Avatar
I was in the same boat been through several NP cases over the years.
The D300 isn't terribly daunting to rebuild with new bearings and seals. You'll need a press, seal driver set, feeler gauges and some shim stock if needed.
Pop the cover off and check your gears before just rebuilding, seems like a lot of guys go with the Terra low kit and twin stick.
Check out gearbox videos on youtube - really good how to on the D300.
Old 03-04-2020, 08:59 PM   #3
hagar is offline
hagar
Vehicle(s): 47 CJ2A 225V6 SM420 D18 w/Warn overdrive D30 5:38 Power Lok D44 5:38 Flanged Detroit Locker
Rep Power: 10 hagar is on a distinguished road
The weakest link will be the T-14. Not the strongest transmission, and weaker then the T176 you are removing.
The T-14 is harder and more expensive to source parts for and they will be made offshore.
I'd keep the T176 and make it work behind the 225.
And that is my opinion.
Old 03-04-2020, 10:47 PM   #4
mattgunguy
Huh.
Wasnt going to use a T-14. Not with a dana 300 t-case & a centered rear axle. Not worth the hassle & then I'd need an overdrive as well. I'm just wanting to know what I should upgrade in the transfer case. Stuff like maybe a tera flex low range kit or something similar. Not worried about rebuilding it. Gear driven cases are fairly straightforward.
Old 03-05-2020, 11:17 AM   #5
Never regretted putting a 4:1 kit in mine.
Gary
mattgunguy (03-05-2020)
Old 03-05-2020, 03:33 PM   #6
mattgunguy
Gary
Thank you.
Only other person I've seen on here from Springfield.
The Following User Says Thank You to mattgunguy For This Useful Post:
Lumpy Grits (03-09-2020)
Old 03-05-2020, 10:35 PM   #7
Belizean is offline
Belizean
Belizean's Avatar
Originally Posted by mattgunguy View Post
Thank you.
I think the only thing Gary knows about Springfield is his trusty 1903 !
Living the dream here on earth, but it's turning into nightmare on Uranus
Old 03-09-2020, 03:34 PM   #8
Thank you.
Moved here last October after 28+yrs in the Mojave Desert.
Love liv'n in America again.
1903??
Gary
Old 03-09-2020, 05:42 PM   #9
Belizean is offline
Belizean
Belizean's Avatar
1903??
Gary
Springfield 1903 bolt action .30-06 caliber rifle. A well made lead slinger for its day
Old 03-11-2020, 10:43 PM   #10
mattgunguy
Lived out far west Texas for many years. While it ain't the Mojave, it isn't to different
Almost 30 years I've been up here, & i still miss west Texas weather though.
300 , dana , questions. , upgrade
Upgrade Dana 30 to 30 splines Swede Drivetrain 6 03-09-2018 07:35 PM
Upgrade to dana 44 front Az84cj7 Drivetrain 26 11-28-2013 12:09 PM
A few questions about ignition upgrade on 304 OEM1984CJ7 Chassis and Body 1 05-31-2012 03:05 PM
Booster upgrade questions tevans59 Misc CJ Discussion 13 07-07-2011 08:41 PM
79 CJ build upgrade questions mysonscj CJ Build Forum 3 02-23-2011 03:52 PM
