Drivetrain Engine, Transmission, Differentials, Transfer case, anything that makes your CJ go forward. |
Dana 300 clutch sleeve questionThis is a discussion on Dana 300 clutch sleeve question within the Drivetrain forums, part of the CJ Forums category; I've read that the clutch sleeves in the dana 300 have a front and back (ie) thick and thin flange ...
03-22-2010, 08:22 PM
Vehicle(s): 1978 CJ7
I've read that the clutch sleeves in the dana 300 have a front and back (ie) thick and thin flange that should go thick to large gear. How important is this. I hope not too!
Re: Dana 300 clutch sleeve question
03-24-2010, 06:12 PM
Well after lookin all over for info and finding none other than its mention and not really seeing any real difference in engagement I've moved on I decided not to repress bearings reseal unit to redo something not confirmed as necessary.
but hard to believe not even an opinion on the subject.
Tvince
03-26-2010, 11:53 PM
NOT the voice of reasonJeep-CJ.com Moderator
Vehicle(s): 1977 cj-5
4.2 W/MC2100 carb, 4.0 head W/3 angle valves,SS Header,TFI ignition with MSB-6 offroad module,CS144 140 amp RPS alternator with remote regulator T-150,d-20,Dana 44 with OX lock and disk brakes. D-30 with Spartin locker,
skyjacker 2.5 lift?nitro shocks,31" BFG A/T off road.8000 lb Warn winch, original owner.=^)
2006 Toyota Tacoma
Tvince
in my opinion, you are doing the right thing.
03-27-2010, 12:16 AM
And thats an opinion I can completly agree with!!
I just got it all sealed up tonight and starting the 176 rebuild tmro
Thread Tools |
Display Modes |
