Default Dana 30, refurb or leave as is?
Old 01-15-2020, 02:29 PM   #1
wadehiers is offline
wadehiers
Vehicle(s): '82 CJ7
Rep Power: 0 wadehiers is on a distinguished road
This has probably been covered before... but I couldn't find it in search. I'm doing a complete restore on a 1982 CJ7. I'm at the point of deciding what to do on the front axle. I've already pulled the axles and knuckles and I'll be doing a full rebuild at the hub end of things, my question is should I worry about anything at the differential? The axles came out pretty clean so I don't think I need to worry about the inner axle seals, but I have no way of knowing how the pinion seal is. (the axle had been pressure-washed before I could check for oil around the pinion tail.) Should I go ahead and replace the pinion seal just in case? Anything else I should be concerned with on a 37 year old axle that I don't have any real history on?
I rebuilt the entire AMC20 rear end (new seals and outer bearings)... but the quality of that axle is tough to compare to.
tks,
-Wade
Default Re: Dana 30, refurb or leave as is?
Old 01-15-2020, 05:24 PM   #2
Patrick is offline
Patrick
Patrick's Avatar
It depends on your expertise, time, money and restoration goal. The very least you can do is check gear lash and contact pattern and overall gear integrity like chipped or signs of excessive wear. You can accomplish this with just the cover removed and axle in vehicle. The pinion seal replacement is cheap insurance. Good luck!
CJ’s are not getting older, they are getting faster!!!
Old 01-15-2020, 07:19 PM   #3
Basod is offline
Basod
Basod's Avatar
Once you get it on the road the axle seal will start leaking and you’ll hate that you skipped it.
There not that hard to do since you already have it mostly apart just be sure to put some marks on the carriers so they go back the same as they came out and grease your seals.
Old 01-15-2020, 10:02 PM   #4
Ultrunner is offline
Ultrunner
Vehicle(s): ‘85 CJ7, 258, T5, D30, AMC20, D300
Rep Power: 2 Ultrunner is on a distinguished road
Concur that you’ll kick yourself if you’ve gotten this far and end up with a leak you could’ve prevented.
Did you change the gear ratio in the rear and? I’m guessing not. A rebuild kit is about $100 and peace of mind. You could also replace the ball joints and u-joints while you’ve got it all apart. Again easy to do for peace of mind. I’d change to sealed u-joints with no grease fittings either. They’re stronger since there’s no channel for the grease.
Old 01-17-2020, 01:01 PM   #5
mriplaybass is offline
mriplaybass
mriplaybass's Avatar
Rep Power: 7 mriplaybass is on a distinguished road
As everyone above stated, it's about peace of mind. I definitely would replace all of the seals, not just the pinion seal. The inner seals are a real PITA to install because you have to remove the carrier, but now is the time to do it. If they are as old as you suspect, you probably damaged them taking the axle shafts out. When I completely rebuilt mine, the new seal on the driver's side began leaking within 4 years. Granted, lots of mud and such found it's way in there, but why mess around with potentially 37yo seals? Here is a video of how to change D30 inner seals. It's a newer Jeep, but the install is the same.
https://www.youtube.com/watch?v=Mbbb... WORDKg&t=854s
If I recall, the back lash is somewhere around .006 to .009. On an axle that has been run for many years, that will increase due to wear and seating of all the components. Don't worry if it seems a bit loose. Check it with a dial indicator to be sure. If you don't have a dial indicator, you can get a rough idea using a feeler gauge, but that is definitely not the tool to use for doing a legitimate set up.
Make sure that you mark the carrier bearing caps and reinstall them in exactly the same position and orientation. If I remember correctly, torque is 60 ft.lb. I always use red lock tight on the bolts. Since you are just taking the carrier out and putting it back in, everything should be the same as it was when removed. I would not mess with back lash, carrier and pinion pre-load, or gear pattern. To change any of this requires removing the carrier bearings since the shims are inboard of the bearings on a D30. Since the bearings are pressed on, you need special pullers, or have to cut the bearings off and get new ones.
Now that I have rambled on, the bottom line is, look at the condition of things once you get the diff cover off. If all looks good, replace the seals and button things back up.
dana , leave , refurb
1983 CJ7 ReFurb. PistolDave CJ Build Forum 34 06-26-2018 05:11 PM
Couldn't leave it alone rob loyd Introductions 6 08-04-2013 09:13 AM
Refurb and Used Parts Gurpgork Misc CJ Discussion 6 05-05-2013 12:05 AM
79 CJ5 Refurb Project - Where to start??? bjorkjc CJ Build Forum 3 03-20-2011 11:29 AM
4.2/4.0 hd/MPI leave as is or go forced induction? Zuni Drivetrain 5 06-05-2009 11:11 AM
