Default Dana 20 Question
Old 02-18-2012, 11:07 PM   #1
Duck is offline
Duck
Vehicle(s): 76 CJ5 258 6, Weber carb, 3spd w/Dana 30 front with Jeep disc brakes and cut down Scout II Dana 44 rear with 11" drums, front and rear geared 3.73,Dana 20 transfer, reverse shackle lift on 31x10.50.
Rep Power: 0 Duck is on a distinguished road
I recently purchased a 76 cj5 with 6cyl,3spd tran,Dana 20 transfer. While draining and replacing fluids in the transmission and transfer (many threads on this site were very helpful, thank you All!!) I became a little confused about which is the fill plug on the transfer case. When I look up from behind the skid plate I see (on the drivers side) a bolt that appears to be a plug but is 6 sided. On the passenger side back of the case I see a square plug. My Haynes manual is unclear which is which. The 6 sided "plug" seems to be higher up so I could get more oil in, but I don't want to over fill. This is my first Jeep and my first post, any help would be appreciated.
Default Re: Dana 20 Question
Old 02-18-2012, 11:40 PM   #2
Dana 20s have had the fill plugs in 2 different locations. Sometimes it is on the side of the TCase. Sometimes it's on the back. I have had 2 Dana 20s and the fill plugs were different on each.
These 2 red circles show the 2 locations.
Fill the TCase until the oil is up to the fill hole.
Old 02-19-2012, 04:06 PM   #3
Duck is offline
Duck
Thank you, however, the second hole with the 6 sided bolt/plug I was referring to is on the opposite end or side of where your two red circles are, adjacent to the yoke for the u joint. Is this something different? Supposed to be a breather or something else?
Old 02-19-2012, 04:38 PM   #4
Rep Power: 14 mtnwhlr is on a distinguished road
All the fill plugs I have seen are 4 sided that is the one I would use.
Old 02-19-2012, 04:40 PM   #5
Duck is offline
Duck
Here is a picture of what I am talking about. The bolt is threaded partially into the hold at the top left of the transfer case. Photo is taken from the rear of the vehicle on the drivers side.
Old 02-19-2012, 06:15 PM   #6
7D8CJ is offline
7D8CJ
Vehicle(s): 1978cj7 glass tub tilt front end 4.5" Rubicon Express lift 304 DUI Holly truck avenger T150 D20 33's , 2010 Rubicon JKU, 2015 WRX
7D8CJ's Avatar
Images: 48
Rep Power: 10 7D8CJ is on a distinguished road
That is NOT the fill plug.
Old 02-19-2012, 06:26 PM   #7
Duck is offline
Duck
Any ideas as to what it is?
Old 02-19-2012, 07:26 PM   #8
7D8CJ is offline
7D8CJ
7D8CJ's Avatar
Images: 48
Had mine apart 5yrs ago. Don't remember what it's for. Chek out this link though.
Pirate4x4.Com - Extreme Four Wheel Drive
****Wish I had more time and money****
Old 02-19-2012, 07:59 PM   #9
CJim7 is offline
CJim7
CJim7's Avatar
Rep Power: 10 CJim7 is on a distinguished road
There's a breather on that housing...but that doesn't look correct
<img src=http://www.pixeldecals.com/shop/image/cache/data/flipoff_smiley_3c-400x400.jpg border=0 alt= />
dana , question
Driveshaft question - T15/Dana 20 in a CJ7 RubberDuck Drivetrain 5 01-20-2012 08:18 PM
Dana 44\30 Rebuild Question project74 Drivetrain 8 01-20-2012 06:26 AM
Dana 30/44 Question XTRAC8 Drivetrain 4 12-15-2011 01:24 AM
Dana 300 Speedo cable question cj5grandnationalturbo Drivetrain 1 02-01-2011 08:58 PM
Dana 300 clutch sleeve question tvince Drivetrain 3 03-27-2010 12:16 AM
