Default Clutch? Spring? Question...???
Old 08-27-2011, 02:57 PM   #1
228jeeper is offline
228jeeper
Vehicle(s): 86 CJ-7, 258, Desmogged, 4 speed T-176, Carter-Weber 2731, headers (no idea what kind), K&N Air Cleaner. Everything else stock as near as I can tell
Rep Power: 11 228jeeper is on a distinguished road
Jeep was running fine when I was downshifting into 2nd to make a turn and I heard something sound like it snapped. Jeep then would shift into first but not without force or grinding. Happened to be close to home so just limped on in. Looked underneath and found this spring hanging. See pic. It seems to be broken off on one end, but I cant find where it would connect to and quite honestly do not know where or which direction it would go or even what it is called. Any help would be appreciated. Thanks.
Default Re: Clutch? Spring? Question...???
Old 08-27-2011, 04:04 PM   #2
228jeeper
OK, could this be what is called an outer clutch fork return spring? I have found an animal by this name on the web, but it looks nothing like the one on the jeep. I can see the hole on the housing of the clutch fork where the current one sits now, but where does the other end go? there is a hole rearward and upward on the bell housing. Is this where that end of the spring goes? Thanks
Old 08-27-2011, 04:45 PM   #3
Ignore the chicken wire. This is NOT my jeep. You can see the clutch return spring here.
It goes from the hole you saw in the clutch fork to a hole in the bellhousing.
This next picture doesn't show the springs but it shows where the 2 ends should go (red circles)
Old 08-27-2011, 04:57 PM   #4
One more thing to add: the clutch fork should pivot on a metal ball. The ball would sit in the detent here.
On these older jeeps the ball may come out when the fork spring breaks. Before putting this back together make sure you didn't loose the ball.
Old 08-27-2011, 05:29 PM   #5
nctom is offline
nctom
Vehicle(s): 77 CJ 7, 258 i6, 3 speed
Rep Power: 10 nctom is on a distinguished road
You can check for the presence of the ball by prying out the rubber clutch fork boot and getting a flashlight in there. It will be pretty obvious. If the fork is sloppy, you may have lost the ball.
Old 08-27-2011, 09:04 PM   #6
228jeeper
Busa, from what vantage point is this pic taken, meaning facing the front of the vehicle, or facing the rear? Whick way dos the spring go, towards the front or back? I think I may have lost the ball as well. I apologize if I dont call these things by the right name, but looking towards the rear from underneath, there is a threaded rod that mates to the indention on the fork. Looks like this is where the ball would go. Can this threaded rod be loosened and a new ball put in there, provided the ball itself can be purchased? Thanks.
Old 08-27-2011, 09:43 PM   #7
That threaded rod is the clutch linkage. When you press on the clutch pedal that threaded rod pushes on the clutch fork. That clutch fork pivots on the ball. The ball is not at the end of the threaded rod. The ball is closer to the middle of the clutch fork. It is just inside of the bellhousing by the rubber boot (part 24 below)
The ball is part 15 in this picture.
That spring is horizontal. It goes along side the threaded rod (parts 4 and 3 above). Here is another picture looking toward the front of the jeep.
And another looking from above.
BTW the threaded rod (parts 2 & 4) screw together to adjust the free play on the clutch pedal. You should have about 1 inch of free play before the clutch starts to disengage.
Old 08-27-2011, 10:05 PM   #8
228jeeper
I see what you mean. I was looking towards the back of the jeep, not the front. Now I have to get a new spring and find where it connects to. Assuming everything else is ok, should this get me back running? And what exactly does this spring do? The spring that was on there was hooked to a hole in the fork towards the end of it, on the outside of the linkage. I have no idea where it was hooked on the other end. BTW, the other two pics you sent did not come through.
Old 08-27-2011, 10:24 PM   #9
Their is one inch of free play to the clutch pedal. This spring holds the clutch fork up against the clutch linkage. If you drive your jeep much wihtout it the clutch linkage may come out of the clutch fork. Then the clutch would always be engaged and the pedal won't work.
The spring goes between the 2 red circles in my first picture. I guess that's not too clear but the front circle is a hole on the bellhousing. Does this picture clarify it any?
See the spring going from the clutch fork to the hole on the edge of the bell-housing. The spring is along-side of the threaded clutch linkage.
Old 08-27-2011, 10:31 PM   #10
Quadratec has the parts you need. Check out this link
Jeep® CJ Replacement Clutch Parts: Jeep® Clutch Kits, Jeep® Throw Out Bearing, Jeep® Clutch Disc, Jeep® Clutch Linkage, Jeep® Clutch Replacment, Jeep® Replacement Fly Wheel - Quadratec
Here's the ball if you need it:
Original Replacement Parts 169162 - Clutch Fork Pivot Ball for 72-86 Jeep® CJ Series & 80-91 SJ & J Series - Quadratec
Here's the spring:
Original Replacement Parts 5351252 - Clutch Fork Outer Spring for 72-86 Jeep® CJ Series & 80-91 SJ & J Series - Quadratec
The grand total is $4 big spender. Shipping will cost more.
clutch , question... , spring
How to Remove & Install Clutch Pedal Spring 1980 CJ5 wildman4x4nut Chassis and Body 14 04-24-2015 08:48 AM
Spring question Farmer Mike Suspension and Steering 0 10-08-2011 01:26 AM
Spring question dalenelson Suspension and Steering 2 06-22-2011 07:01 PM
Squeaky clutch spring nctom Drivetrain 2 01-07-2011 07:48 PM
spring question pauld3 Suspension and Steering 1 11-25-2009 05:39 PM
